1021 - 1040 of 1210 Posts
Nitto 305/50/20's ordered up. Should be a 32" tire. So hopefully they don't look too small.
Warning: They WILL look too small to YOUR eyes after being so used to the current macho stance.
You have to look away as you get in the truck for awhile. Lol
Use the tuner to update the tire size. Start her up. Get it warm. Then....... Oh my, this thing was bleeding THAT much power loss wearing them big boots?
It's just physics.
By the way, as wierd as it will look to you, you'll get compliments on the truck with the low profile look. It's just a different group that suddenly likes your truck that didn't before. ;)
163197
love love them. Very very good taste in a not very easy color selection. Well done. Seriously
You do realize his truck isn't black?
You know, RMB Black?
The only color Ryan Brown thinks any truck looks good in?
Funny thing until these two trucks, 100% were white other than my Harley Davidson 350 powerstroke
Discussion Starter #1,028
Tires should be mounted up by tomorrow. I doubt the "street' look will really fit with the truck, but they will serve their purpose nicely.
I bought a pair of kicker components for the front doors some time ago and decided to at least get the speakers done at the same time I do the Sync 3 upgrade.
I found a new set of KST25 Tweeters for the A pillars, CS 3.5" for the center speaker and two-way 6x8 CS Kickers for the rear doors. This should work nicely with the stock deck and leave me room to amplify in the future if I ever do it.
Let's know how it sounds! I'm wanting to replace the factory speakers in my truck with a nice upgrade so hoping you'll have good results
Discussion Starter #1,030
I need to get some pics up, but I was able to install the kicker Tweeters with associated cross-overs last night. I hope to tackle the front door speakers and center speaker (along with mounting the new GPS antenna) tonight/tomorrow.
Looks great! How do they sound? Was it tough getting the A pillars off?
Discussion Starter #1,034
It is better with just even swapping these three speakers. More “mid” coming through.
A-pillars come off pretty easy. Drivers just pulls off and the passenger is pulling the two 7mm bolts in the handle and then giving it a quick pull.
Getting these tweeters in was a little bit of work as I had to use a Dremel and enlarge the holes. It soldered the kicker wires into the stock connectors to make it a little cleaner of a install.
I thought 15 plus wheels have different offsets or backspace or something and don't work on our trucks? I really like those wheels since day one, i want them.
Is your truck raised or leveled? A bit of a wheel gap, looks more than mine stock, would be nice if you got a bit more sidewall but they probably dont have it in those tires.
Discussion Starter #1,037
The 15+ wheel bolt right on, you just gotta use you current lug nuts. This is the second set like this that I’ve run with no problems whatsoever.
Yeah I would have gone with 33” tires instead of 32’s if they existed. I really wanted the 420s specifically, so I was limited on sizes. These are as big as you can go @305/50/20.
Truck sits pretty close to stock height in the back, maybe .75” higher than stock and front is about 1.75” higher than stock with the way the coil-overs are set right now.
