1181 - 1200 of 1258 Posts
Discussion Starter #1,183
I have been able to get a few things done on the truck in between holidays and Family time.
Fixed the rattle in the drivers door. I found that I lost one of the rubber stand offs. Replaced it and put the door panel back on and was good to go.
When Installed Sync3, I forgot to plug the 12v connector back in l, Sinai had to pull the airbag to get that back on.
I finally got around to putting the Ready lift leafs in the back and adjusted the fronts up a bit to kill some of the rake.
Before
With just the leafs in
Front lifted up a bit more than before
I had to cram the spring compressor in the front to get a few cranks on the springs.
I expect the rear leafs will settle a bit and then I’ll be happy with the rake.
Next up is Mishimoto coolant tank.
Discussion Starter #1,184 (Edited)
Current upgrade list
Exterior
RCI Aluminum Skid Plates
Method Racing wheels with 305/55/18 KO2's
Nitto 420s 305/50/20 on Custom Powder coated OEM 2017 Sport 20's
Raptor Running Boards
MX GrillCraft Grill
Expel film on front Bumper
Spray in Box liner
Rigid SAE Fog cubes
Removed lower air dam
Access "Vanish" tonneau cover
AVS in-channel visors
AVS bug deflector
Ready Lift AAL (+1.5")
Fox 2.5 Coil-overs with DSC
Fox 2.0 Rear shocks
Rear wheel well liners
EZ Tail Gate assist
Pop a lock tail gate lock
LED bed lights
Recon 3rd Brake light
Recon Tail lights
Recon LED puddle lights
ANZO LED marker lights
Flat black FX4 Bed decals
Custom flat black "EcoBoost" decals
Custom Blue Flame Painted F150 emblems
Custom Blue Flame Painted FORD rear emblem
12v/5v Power outlet in box of the truck
Fumoto Valve
Rough Country Hidden 1010 winch mount
SmittyBilt 10k "X20" Winch
BuiltRightIndustries Bed rack/panel system
  • Axe
  • Hatchet
  • Hi-lift Jack
  • 3.5 Gal Rotopax Gas can
  • Hand Saw
  • Flashlight
  • Spade Shovel
  • Traction mats
  • ADD Bed liner coated Rear Bumper "Dimple R"
Yakima Bed Rack system (Mounted to Bed rails)
PowerStop Rotors with Raybestos hybrid pads
Kevlar Brake lines
Spicer Rear Diff Cover
Aimsoil Fluid in front and Rear Diffs
Interior
Raptor Steering Wheel w/Blue Vinyl Centering Stripe
WeatherTech Digital Fit Mats
3M protective film on the door sills
Sync3 Non-Nav Head Unit
Kick KS Tweeters
Kicker CS 6x8's in all doors
Kicker Subgate upgraded sub
DRW-650 2-channel dash cam
Custom Hydro dipped door panel inserts and stereo surround
Full LED interior light conversion
Custom overhead light switch panel
CravenSpeed Dead Pedal
BuiltRightIndustries - Rear Seat Latch
Performance
RMB Built Motor!
  • Closed Deck Block
  • Custom JE Pistons with Custom Ring Set and Coating (9.5:1)
  • Manley I-Beam Rods
  • Gen 2 Crank (micro polished with modified oiling)
  • Pocket Port "R" heads
  • Upgraded Valve Springs w/OEM Valves
  • Custom Grind HPFP cam
  • XDI-35 HPFP
  • Return Fuel System with Injector Dynamics External filter, Walbro 450 Fuel Pump, Radium regulator, B&M fuel line
Circle D Torgue Converter 2500-2700 Stall
SCT Xcal4 Tuner with @Boostking and @mattr66 tunes.
Full Race FMIC in Black
Tial BOV
AFE Stage 2 CAI
AMS Boost tubes (Gen 2, custom install)
2019 Raptor Turbo/OEM Turbo Hybrid's
CRP Manifolds
SPD Turbo adapters
Full Race Catted and Ceramic Coated DP's
Full Race Resonated Cat-Back
Full Race Catch Can
Full Race Gen 2 Radiator
Remote oil filter using Improved Racing Adapter and remote mount
Setrab remote oil cooler
Ford Raptor "Saudi" Trans Cooler
To be installed
Stifflers Traction Bars
Mishimoto Coolant Tank
PacPro Amp converter (need to decide on a Amp)
Exterior
MX GrillCraft Grill
Spray in Box liner
Rigid SAE Fog cubes
AVS bug deflector
Fox 2.0 Rear shocks
EZ Tail Gate assist
LED bed lights
Recon Tail lights
Fumoto Valve
  • Axe
  • Hatchet
  • Hi-lift Jack
  • Hand Saw
  • Flashlight
  • Spade Shovel
  • Traction mats
Kevlar Brake lines
Interior
Kick KS Tweeters
Performance
RMB Built Motor!
  • Closed Deck Block
  • XDI-35 HPFP
SCT Xcal4 Tuner with MPT tunes (87 perf/chill, 87 tow/street, 91 Perf/street, 91PRX, 93PRX)
Tial BOV
AFE Stage 2 CAI
CRP Manifolds
SPD Turbo adapters
Full Race Catch Can
To be installed
Very impressive. Do you have a cost column associated as well or do you pretend not to look at that. Ha
LOVE the first video!
I had the phone Bluetoothed to speakers for background music while I was working remotely at 2am this morning. During a few minutes of idle time I clicked the post, and immediately this crazy blue truck's exhaust note filled the air. Lol
Dang that thing sounds pretty healthy.
Nice playground too.
Loved the video of you romping on that RMB motor. Your truck is badass.
I agree with Snake, That first video sounds awesome! Truck sounds super mean! Do you have a cold startup video too? I really hope mine sounds that good
Discussion Starter #1,192
Thanks guys! It was a load of fun. The guy I went with has a nice Borla exhaust set up on his 5.0 and it sounded really nice. He was surprised at how nice my “Eco” sounded .
I can get you a cold start vid shortly.
Well when you make that motor as nice as you did of course it's gonna sound amazing you're running the full race exhaust right?
I should probably just check the mod sheet again
Edit: looked and got my answer!
Discussion Starter #1,194
Yup, Full Race from the DP’s to the tip.
I forgot got to mention, this was wringing it out to 6500 rpm...zero rasp.
Wow! 6500rpm and it sounds that good! I'm super stoked to get mine back now if it sounds close to what yours does I'll be a happy camper!
That truck is turning into one sweet ride sir! Congrats on the best sounding truck on this forum
I think the "sound" is cheating just a bit since that epic environment added some "epic" echo to the clip. Lol
It does sound wicked.
I love how stuck the 15 was, reminds me when i buried my 15 to the frame in mud! XD
Discussion Starter #1,200
