1401 - 1420 of 1440 Posts
Discussion Starter #1,401
I received the package at home, so the kids tell me. :)
So, that's a negative on installing. I haven't even been home to open the box.
And you should know by now that even if I was home, unlike you and your get-r-done methods, I'm likely to procrastinate?
Although I'm kinda excited about this because I really appreciate high end products. Bucket-list stuff, if you know what I mean. So I might get it done soon.
I know you don’t give into pressure, but I would really like to hear your opinion on it. I think it’s the best I’ve heard in person, period.
You have more influence than you might think.
Or to put it another way, there are some pressures I'm happy to succumb to.
Discussion Starter #1,409
fuel pressure issue?
A few posts up, you’ll see I had a bit of a pressure dip when locked in gear and doing a WOT run. I’m also hoping that with the 60% pump, I can get a little more out of the stock injectors, as they will be my limiting factor and I’m pretty close to that limit now.
With the changes made recently and the tuning updates from BK, I’m pretty confident that I’m around 530-540whp now.
I kinda know how it would do. Or at least how it feels.
Since I'm lighter and at 29' above sea level.
These things are amazing. And most of us are now jaded about it. Lol
Discussion Starter #1,418
With a few things done recently, time for a updated list.
Just gotta go back into selling/working mode so I can get the lift done. I have been pretty lucky and have had a few vehicles come for detailing to fund my habit, lol.
Exterior
RCI Aluminum Skid Plates
Method Racing wheels with 305/55/18 KO2's
Raptor Running Boards
MX GrillCraft Grill
Starky Raptor grill light kit
Expel film on front Bumper
Spray in Box liner
Rigid SAE Fog cubes
Removed lower air dam
Access "Vanish" tonneau cover
AVS in-channel visors
AVS bug deflector
Ready Lift AAL (+1.5")
Fox 2.5 Coil-overs with DSC
Fox 2.0 Rear shocks
Rear wheel well liners
EZ Tail Gate assist
Pop a lock tail gate lock
LED bed lights
Recon 3rd Brake light
Recon Tail lights
Recon LED puddle lights
ANZO LED marker lights
Flat black FX4 Bed decals
Custom flat black "EcoBoost" decals
Custom Blue Flame Painted F150 emblems
Custom Blue Flame Painted FORD rear emblem
12v/5v Power outlet in box of the truck
Fumoto Valve
Rough Country Hidden 1010 winch mount
SmittyBilt 10k "X20" Winch
Factor55 Ultrahook
Demon hook mounts with Gear America “D” Shackles
BuiltRightIndustries Bed rack/panel system
  • Axe
  • Hatchet
  • Hi-lift Jack
  • 3.5 Gal Rotopax Gas can
  • Hand Saw
  • Flashlight
  • Spade Shovel
  • Traction mats
  • ADD Bed liner coated Rear Bumper "Dimple R"
Yakima Bed Rack system (Mounted to Bed rails)
PowerStop Rotors with Raybestos hybrid pads
Kevlar Brake lines
Spicer Rear Diff Cover
Aimsoil Fluid in front and Rear Diffs
Interior
Gen 2 Raptor wheel with paddles shifters
WeatherTech Digital Fit Mats
3M protective film on the door sills
Sync3 Non-Nav Head Unit
PAC AmpPro converter and speaker harness
Kicker 360.4 with 4ga power wiring
Kick KS Tweeters
Kicker CS 6x8's in all doors
Kicker Subgate upgraded sub
DRW-650 2-channel dash cam
Custom Hydro dipped door panel inserts and stereo surround
Full LED interior light conversion
Custom overhead light switch panel
CravenSpeed Dead Pedal
BuiltRightIndustries - Rear Seat Latch
Performance
RMB Motorworks Built Motor!
  • Closed Deck Block
  • Custom JE Pistons with Custom Ring Set and Coating (9.5:1)
  • Manley I-Beam Rods
  • Gen 2 Crank (micro polished with modified oiling)
  • Pocket Port "R" heads from HeadGames
  • Upgraded Ti Valve Springs w/OEM Valves
  • Custom Grind HPFP cam
  • XDI-60 HPFP
  • Return Fuel System with Injector Dynamics External filter, Walbro 450 Fuel Pump, Radium regulator, B&M fuel line
Circle D Torgue Converter 2500-2700 Stall
SCT Xcal4 Tuner with @Boostking and @mattr66 tunes.
Full Race Intercooler in Black
Tial BOV
AFE Stage 2 CAI
AMS Boost tubes (Gen 2, custom install)
2019 Raptor Turbo/OEM Turbo Hybrid's
CRP Manifolds
SPD Turbo adapters
Full Race Catted and Ceramic Coated DP's
Full Race Resonated Cat-Back
Full Race Catch Can
Full Race Gen 2 Radiator
Remote oil filter using Improved Racing Adapter and remote mount
Setrab remote oil cooler
Ford Raptor "Saudi" Trans Cooler
Mishimoto Coolant Tank
Stifflers Traction long bars
All I can say is WOW 😳
Reactions: sleipnir
Yea, you weren't here while he was building.
It's perhaps the most "Sorted" Gen1 Ecoboost around. And I don't mean just under the hood.
Nor is this a glorified grocery fetcher dressed like an off road toy. How he keeps it dentless baffles me. Lol
