Just ran across this press release on Autoblog.... This truck certainly won't be a F150 killa
Now the question is what type of gas mileage will it get towing 9200 pounds.
Ram Announces New EcoDiesel Max Towing Number
2014 Ram 1500 Achieves New Best-in-class Tow Rating for V-6 Gasoline Pickups
- 2014 Ram 1500 with 305 horsepower Pentastar V-6 tows 7,450 lbs., topping all base V-6 engines in the segment
- More robust parking system components inside the exclusive 8-speed transmission allow for greater tow rating
- 3.0-liter EcoDiesel towing capacity rated at 9,200 lbs. - approaching large V-8 capability
- No direct competitor for new Ram 1500 3.0-liter V-6 EcoDiesel with best-in-class fuel economy that will exceed the current title holder, Ram's 3.6-liter V-6 gas engine at 25 MPG
The capability race is far from over. The 2014 Ram 1500 takes top spot in V-6 towing capacity at 7,450 lbs. To reach the best-in-class number, Ram powertrain engineers added a more robust parking gear to the exclusive 8-speed TorqueFlite 8 for a higher capacity rating.
"There was more towing capacity in the V-6 Ram 1500 but we needed to upgrade the transmission to hold the truck and trailer when parked on steep grades," said Mike Cairns - Chief Engineer, Ram Truck. "Now that we're building the transmissions ourselves, the improvements are included in the new assembly. "
Ram also finalized the maximum towing number for the exclusive Ram 1500 EcoDiesel. In a 2WD, two-door, long bed configuration, the new EcoDiesel will tow up to 9,200 lbs. The new diesel engine approaches much larger displacement V-8 towing capability with a small but powerful 3.0-liter V-6 and best-in-class fuel efficiency of better than 25 MPG on the highway.
