Does anything else need to be replaced when changing the plugs? Are motorcraft plugs the ones to get?
Never use anything but FORD -OEM Plugs by motorcraft.
I replaced the PCV valve and the small boots on the coil packs.
I feel that so strongly !My truck wasn’t running bad or anything either. It’s just on this forum you get worried that you might be doing something wrong if you didn’t. My gap did increase to 40 though. On old plugs.
SP580. Or LTR6BHK if you want to go NGK Rutheniums (but they are higher priced than MC). Don't buy off Amazon - too much counterfeit crap up there.2013 3.5EB, original plugs, 130k, lots of racecar towing......😬 searching plug numbers now....
SP580 is the current correct plug for my 2018 3.5. And the NGK should be LTR6BHX, whoops!TVSJR and the Pro's: I have seen SP550 and SP580 listed for the 3.5 EcoBoost. Which is preferred for stock Gen 2 F-150 3.5 Ecoboost (2019) primarily used for towing?
or the LTR6BHK NGK Ruthenium's?
That's what NGK thinks as well...Best question asked so far. I add to it:
Some pretend to be wrench turners think that the new spark plug Nickle plating negates the need for an anti-seize compound. What say our Pro's here?
Thanks. I believe that those S/N's would be the same for the 2019 version as well.SP580 is the current correct plug for my 2018 3.5. And the NGK should be LTR6BHX, whoops!
Very well put! These items are inexpensive, easy to change and a great reason to go play in the driveway🔧😁It's a similar debate to oil change intervals. There's definitely more than one perspective.
I'm wired to looking at it like from the MOMENT I pour brand new oil in the motor it is only perfect oil until after its first heat cycle. Then it's 99% perfect
Then 98%
Then 90%.......
See the dilemma? Unlike most things, I'm hopelessly a glass-half-empty oil guy because of this.
Another way of putting it is if for some unknown reason I needed to drain my oil with only 1000 miles on it, I could NEVER pour it back into my motor. Because I have 6 quarts of BETTER oil on the shelf. Why wouldn't I pour the best oil I have available to me into my motor?
My plugs might still be making spark at 35000 miles. In fact, of course they are. But the brand new ones on the shelf are perfect. PERFECT. 🤣🤣
I want my internal combustion engine to be PERFECT as much of the time as I deem reasonable.
I'm my own worst enemy. Lol
