1 - 3 of 3 Posts
I bought a upr dvcc for my 2015 2.7L EcoBoost. I am not for sure how the clean side pipe mounts. I know the location where it mounts. Just not for sure the direction it mounts. Any advice would be highly appreciated. Thanks
20181020_114734.jpg Does the side I'm pointing at go to drivers side turbo pipe or driver side valve cover.
The plastic line is rigid and does not bend. You install the CSS on the cam cover, then gently rotate it clockwise until the connector lines up with the turbo pipe connection.
1 - 3 of 3 Posts
