Im in need of some help with a problem that seems to have been popping up lately with my 2015 Screw 3.5. I keep blowing fuse 59 which is my starter fuse in truck. Not every time does it do it though. Does anyone have a wiring diagram for these trucks im wondering if i could visually check where wires may be going for any brakes or chew marks. I also noticed that last time i started my truck with the auto start feature the starter stayed engaged for probably 3-5 sec after the truck was started. Could that be causing a rush of power or could my starter be toast and causing my truck to blow this fuse? The starter has been starting the truck without a problem however the starter being engaged after the truck is started is a new development.
Any help would be great.
