1 - 7 of 7 Posts
Hello all,
I have done a ton of reading before deciding to make a post on this. I’ll start out with a background of when my issues started. I purchased the 2016 EB about 8 months ago with 95kmiles.
I ran Chevron fuel system cleaner through it with ethanol free fuel on two full tanks. Afterwards I changed the plugs to the NGK iridium LTR6IX with a .032 gap. I got intermittent catalytic codes for both banks and after 2 months I started getting small shutters when the turbos were under load at 60mph+. Last week, I got 3 misfires along with the catalytic codes. I purchased both new magnaflow catalytics and installed them yesterday. Very expensive! Upon reading, I discovered the “weep hole” mod and went ahead and done it. About 15 drops of oil came out and then stopped. I pulled a travel trailer yesterday and the misfires started. Anytime I go up a hill faster than 35mph it feels awful. If I push it too hard, it’ll go into limp mode and I have to stop for a couple Minutes. This morning, I read the code and it had a P0304 cylinder 4 missfire with no other accompanying codes. This truck is basically stock. The only thing I’ve done is the VTA mod when I first got it. It does have a lift and bigger tires. Please help!! I have a camper to tow home and am afraid it won’t make it!
Thank you!
Misfires can be caused by many things.
Coil, coil boot, plug, fuel injector, vacuum leak, low compression, leaky head gasket. The first 5 are more common but the others can happen.
Discussion Starter · #3 ·
Copy. Thanks Scott.
Tuxedo Black 2012 F150 SCrew XLT EcoBoost
I'll preface this by saying I'm really new to the EcoBoost. But when I had my shudder issues I took the forum's advice and replaced the plugs with a .029-.03 gap. All my factory plugs were gapped around .032-.037. I've had zero issues since gapping them smaller. From what I've read, the next step is troubleshooting the coils.
My code was also p0304/cyl 4 misfire
Discussion Starter · #5 ·
Copy that! Did you use the Ford plugs?
1 - 7 of 7 Posts
