1 - 20 of 20 Posts
I have a 2017 F150 3.5 EB 6.5 bed with max trailer tow package. I just bought a tow behind camper that weighs 8900 lbs. on take off or acceleration I have a vibration/shutter through the rear/ towards the center of the truck. Once up to highway speed it’s gone. Maintaining speed it’s not there. Only when starting and it really depends on how I get on it. Has anyone experienced this and if so what corrections can be made, if any. FORD says this truck can tow - and I’m not even at the MAX tow limitations. I was using a WDH as well.
Thanks
If you are talking about the slight vibration or shudder at take off when you have a heavy load or heavy trailer, it's covered in your owners manual.
It's usually a result of the rear driveshaft and/or axle wrap, which is when the axle twists under the leaf springs from the torque. It's more common in the 157" truck due to them using a two piece rear shaft I believe.
Mine kind of does it, but not bad.
Is there a fix?
My 2009 157” truck did it and my 2016 157” truck does it. Axle wrap. Take off a bit slower until you get past that resonance. You could also try roadmaster active suspension as it has helped some folks.
Super Modistrator
Axle wrap is not specific to Ford. Trucks have been fighting that when towing for a very long time.
Discussion Starter #12
I have towed with 3/4 and 1 ton trucks under load and have never experienced what I have experienced in my F150 - I am
however trying to somewhat push the limits. I just know I’m under max tow rating by a lot.
Super Modistrator
Ford doesn’t say this problem is only evident when near or exceeding load capacity. They’re simply telling you that you might experience it. That doesn’t mean that every 3/4 or 1 ton truck has the same issues. One of my F150‘s did this.
I think I slightly notice mine doing it slightly. I thought it was the torque convertor.
Super Modistrator
I suspect your problem will be solved when you get your track bars on. :p
Discussion Starter #16
Trac bars? I think that’s a great idea - my guess is it will stabilize the axle balancing out the wrap! I love my truck I just want it to perform like the beast I know it is! Lol for a half ton!
3/4 and 1 ton trucks have far stiffer springs. Thats helps a lot.
An intake is just for looks and sound unless you are making big power.
Also, the AMS turbo inlet tubes are much more effective than an intake. But at the end of the day, you are gunna need a tune to take advantage of any engine mods. The PCM will compensate for any flow improvements and continue to produce stock power without a tune.
1 - 20 of 20 Posts
