In stock and on sale through the end of August!
2018-2020 F150 Morimoto XB Gen 2 LED Headlights LF501.2-ASM
Highlights:
Morimoto's lineup of XB LED headlights are an awesome, aggressive, and high-quality lighting upgrade for practically any truck on the road, but Morimoto's new Gen 2 XB Headlights for 2018-2020 F150s take the XB's styling and lighting capability to a whole 'nother level. The Gen 2 XB LED Headlights offer up even more light output than the first generation XBs thanks to even more powerful LEDs in their quad-stacked projector lenses and an improvement in styling with an "eyelid" style projector design and two-stage warmup sequence that is sure to turn some heads when you startup your awesome 2018-2020 F150 build. XB Gen 2 headlights use four of their eight projectors for the low beams and the final two for high beams, which adds to their total low-beam output to give you better visibility without switching to your high beams. The XB Gen 2 Headlights come standard with an LED outline that features a white DRL function as well as a scanning, sequential amber turn signal on the top line of the headlight that gives your truck an awesome, aggressive look 24 hours a day. The XB headlights feature a clear polycarbonate lens and a black housing that lets the headlight fit in with practically any F150 paint color or styling theme. The headlights install right into place of your F150's factory headlights and come with a complete wiring harness that allows you to get the XB Gen 2 headlights up and running on your truck right out of the box.
Quad Kuria Projectors with Powerful LEDs with Sequential Turn Signals and White DRL Outline
The Morimoto XB Gen 2 Headlights combine powerful LED boards with highly-specialized projector optics in a headlight system that's loaded down with features. Morimoto builds each of their headlights around a full set of four Osram Ostar LEDs that work together to produce up to 2600 raw lumens per headlight at a pure white 5500K color temperatures. The huge power of the LEDs is harnessed by Morimoto's Kuria Optics that generate a clear, crisp beam pattern with excellent range with a distinct cutoff that keeps the headlights from blinding other drivers. The projectors themselves have a revised design with a noticeable "eyelid" styled after the newer Expeditions. The LED outline taps directly into your F150's fuse box using the included wiring harness to give your truck a true DRL function instead of being tired into your parking lights like most other headlights. The amber sequential turn signal scans from the inboard of the headlight to the outboard when you activate your turn signals or flashers for a great look. The polycarbonate lenses are completely clear to allow the headlights to shine as much as possible. The Morimoto XB Headlights are drop-in replacements for the stock headlights and come with a complete set of wiring harnesses and instructions. These headlights are DOT and SAE approved for street use in the continental United States. Morimoto backs their Gen 2 XB headlights with a 5-year limited warranty.
Fitment: 2018-2020 F150.
Fits both halogen and LED headlights: these headlights will fit F150s with both OEM halogen and OEM LED headlights and comes with instructions for both installs.
Deletes Auto Dim function: these headlights do not preserve the stock Auto Dim function of the high beams, though they will still install onto a truck equipped with Auto Dim.
Highlights:
- Improved power and look over 1st gen XBs
- 2600 raw lumens per headlight
- 5500K color temperature
- Quad projectors with powerful LED boards
- White LED outline strip with true DRL functionality
- Amber sequential LED strip
- Clear lenses with black housings
- Drop-in replacements with stock
- Come with wiring harnesses
- Backed by a 5-year limited warranty
