1 - 1 of 1 Posts
Quite a few of these in stock and ready to ship, pm me for forum pricing!
2018-2020 F150 Morimoto XB Hybrid LED Headlights (Gunmetal) LF551
Automotive parking light Automotive tail & brake light Vehicle Automotive side marker light Automotive lighting
Highlights:
  • Sleek look and great lighting in affordable package
  • Dual high and low beam LED projectors
  • DRL LED outline strip with white color
  • Aggressive Gunmetal housing
  • Drop-in, plug-and-play finish
  • For base halogen trucks only
Adds and Awesome Look and Improved Output for your F150
Morimoto's lineup of XB headlights are a high-quality, stylish, and potent lighting option for your 2018-2020 F150, and the Morimoto XB Hybrid LED Headlights now give you Morimoto's legendary name in a much more affordable package than the standard XB LED Headlights. The XB Hybrids feature a much more traditional dual projector design, and uses highly effective Bi-Kuria optics powered by Osram LEDs that deliver a ton of lighting in a clean package. The Hybrid XB headlights come standard with a white LED outline strip that ties in with your F150's parking light wiring and gives you an aggressive running light that looks great both at night and during the day. The headlights feature a unique Gunmetal finish for their housings that gives them one of the most distinct looks on the market. The headlights are designed for a drop-in, plug and play installation on your F150 and come with everything you need to get them up and running on your hyper-tough F150 build. Dual LED Projectors with LED DRL Outline Strip and Gunmetal Housings
Like the rest of Morimoto's XB headlights, their Hybrid LED Projector Headlight are built to last and features high-quality components that won't let you or your truck down. The Morimoto Hybrid XBs are built around a pair of LED projector projectors for both the high beams and low beams. Each projector features Morimoto's Bi-Kuria Optics that harness the LED's light output into long-range beams with a crisp cutoff that prevents you from blinding other drivers. The projectors are powered by Osram LEDs with a 5000K color temperature for a nice, pure-white color for the beams that's easy on your eyes and still adds a stylish look to the headlights. The LED outline strip features a single-function DRL with a similar 5000K color temperature as the high and low beams. The projectors, turn signals, and parking lights are all set in a housing with a Gunmetal finish whose gray look is sure to turn some heads. These headlights drop right into F150s with base halogen headlights without any modifications and has plug-and-play wiring.
Fitment: 2018-2020 F150 with Base Halogen Headlights
For Base Halogen Only: these headlights will only fit F150s with OEM base halogen headlights and will not fit F150s with OEM LED headlights.
Requires 7443 turn signal bulbs: some 2018-2020 F150s could come with 3157 turn signal bulbs. However, these Morimoto headlights are only compatible with 7443 bulbs, and you will need to replace your 3157 with a 7443.
1 - 1 of 1 Posts
