1 - 1 of 1 Posts
The wife's 2018 3.5 has a rodent chewed wiring issue with a knock sensor harness. I have found a lot of information in replacing it (sounds to be a bit for one little sensor), but when talking to the stealership service department they said that it would cost around $1200 to have them fix it due to "single use fuel rail components" that are 20+ days backordered. I understand that gaskets, o-rings, etc should be replaced, but they were talking hardware components as well. I havent found anywhere that talks about these single use components on here or the rest of the interwebs, and am curious if anyone has insight before I decide to tear into it myself and just reuse the hardware that is there.
1 - 1 of 1 Posts
