1 - 14 of 14 Posts
After cj I'll be ready. Ordered 5100's front and rear yesterday, should be here in time for next weekend. I was thinking the 4600's would do fine but I found the 5100's for just $20 more,who could resist?
When talking ride quality and handling the price difference is negligible.
2018 SCREW Platinum 3.5
If you have any issues or questions feel free to ask on here. Pretty straightforward install.
Super Modistrator
Gotta be honest here, I didn’t know that Bilstein made a shock for a 3” lift in the rear. The ones that most of us have installed are only good for an inch over stock.
Funny you should post this as I installed my 5100s yesterday as well. Funny thing with mods like this... if I had to do it one more time, it'd only take half the time... but I'll probably never have to do it again!
:eek:
Feel free to ask any questions.
Some help please
Ok... A couple or 3 questions for the thread. Need some honesty bout the right shock for our situation.
First .. We have pertnear 50K on the ole 2013 truck. Suspension is still stock, no add-ons. We tow a 5th wheel and the ride still is great but thinking it's about time to replace the ole stock Rancho's. Truck sets 2 1/2" higher in the rear unhitched and 1/8 - 1/4" high with the 5th wheel hooked up. Truck needs the 2 1/2" difference in height to ride pertnear level when towing. We tow quite a bit with it so we'd kinda need to keep the 2 1/2" rake.
1. Will a set Blisten 5100's for both the front & rear let me keep the same 2 1/2 " difference unloaded & give at least the great ride like we have now or
2. Do we need to look at different Blistein.
Just Spit balling here... Maybe an adjustable one for the front? So unloaded, front could be raised to ride level unloaded & then dropped back down when loaded. Is that a viable option and how much trouble would that be to readjust each time? or
#3. Go with Rancho's again?
Thanks
Milo
Discussion Starter #9
Some help please
Thanks
Milo
Yes the 5100’s will let you maintain the stock ride height. Shocks don’t affect ride height. The 5100’s in the front are adjustable yes, but are not simple to re-adjust down the road.
Discussion Starter #10
Here is a picture with the 2” rear block installed. 285/60/20 toyo open country tires going on on Monday.
Whats the difference between the 6112 and 5100? They look very similar. Is it just that the 6112 comes with its own spring?
The shock body on the 6112 is substantially larger in diameter, and the spring rates are different. Apparently the spring rate is higher than most of the F150 configurations, but equal/slightly lower than a loaded Max Tow or HDPP.
1 - 14 of 14 Posts
