I have to keep up with that mighty 2.7 you have with those hefty set of lungs breathing all that air!!!!Nice! Time to start rolling corn!!!
Must have been pulling pretty dang hard because it still went a 12.54 with a 4.28 0-60. Imagine what you will do with a 3.9 0-60Alrighty
Just did a draggy and data log for Torrie, for Rev 2, on E50. Just need to see what Torrie says about the log..... my look at it, appears to be good still, definitely the fuel pressure is still good.
The draggy for the 2nd attempt of the day leaving at 3k
This was the second 1/4 attempt of the day as the 1st was slower at 12.79 with 4.65 0-60 didn't launch hard 2400/500 ish
I have been trying to talk the wife into letting me get "her" an explorer st.... Lol,,,, Calibrated tuning has an st or two in the very very low 12s on their e30/40Awesome results!!
I would guess that you could shave close to 2 10ths with stock tires if they hooked.
With anything 2017+, a AO tune should be fairly close to a dedicated tune as you can impact spark and boost based on fuel quality. Now there is still something to be able to be said about a dedicated tune that has a narrower fuel quality window as most tuners feel more comfortable tuning mow power out of it as there is simply less variables.
Now seeing those times, I’m gonna try and beat them with the ST on e30. We’ll see how it compares, lol.
Well I dont know, maybe I should check and open a boxDid the ones you picked up have the little ground electrode pillow?
Do some not have them?Did the ones you picked up have the little ground electrode pillow?
I would be careful going too cold of a plug. The FP plugs are already one step colder than stock. Even a heavily modified F-150 will not meet the cylinder pressures seen in the Ford GT.Was in town at the hardware store and decided to walk next door to the Napa that has been in town for 30 years, and seem to always have what I need or can get it next day.... To my surprise they had a set of the NGK Ruthenium HX LTR7BHX 95605. They are one step colder, so I will be replacing the Ford Performance M-12405-35T also a one step colder plug.
After countless hours of forum, internet and other researching, I think for me and for many reasons, the NGK plugs are pretty darn good in my mind ,,,,, far less issues than the Motorcraft GT plugs and I am sold on the fact they are a better plug at this point
There’s a reason I run oem ford plugs.I would be careful going too cold of a plug. The FP plugs are already one step colder than stock. Even a heavily modified F-150 will not meet the cylinder pressures seen in the Ford GT.
Edit: I read that wrong. You should be fine tho. I am also weary of those “tabs” breaking off.
Yes, they look like the PSPE.......Yes, there are 2 types. The "pillows/tabs" were designed for forced induction engines. Gotta admit that I have wondered if these could pop off.
I feel you, but I am going by what the tuner(s) suggest, given the tune, the E Content and so forth.....There’s a reason I run oem ford plugs.
