1 - 17 of 17 Posts
You don't need to keep posting this in other sections.
This is the correct spot. Leave it here.
There's a couple guys that seem to like to do that, copy and paste the same damn post in multiple threads. Annoying
We'll see
Sent from my Pixel 2 XL using Tapatalk
I don't know. Sometimes the crosspost/doublepost is a result of a recent gorgeous picture.
Seeing it in two different threads is the equivalent of a "double take", much like when you see something at a glance and it takes a second for your brain to register and then it sends a demand-request to see it again.
I'm not saying this engine cover warranted such, but it certainly isn't hard to look at. :)
Discussion Starter #14
Just so everyone knows these covers are foam, not plastic. The foam is 2-3" thick through our the mold and feel very durable. Also, if your existing cover doesn't have the 2 10mm studs to hold the front on and a hinge style rear clip they won't work.
For the early gen 1 trucks 2011-2014, I know there isn't any place to screw in the two bolts up front. Maybe it will clip in the rear and be able to just sit there. I guess we will see when he tries his. It is a sexy cover though.
Does not work for Gen 1, I will probably try and modify mine to work however :)
1 - 17 of 17 Posts
