1 - 8 of 8 Posts
For the past few months sometimes when I go to start my truck up the truck will lunge forward after you start it up. I don't understand why it's doing this especially if it's in park!! Has anybody who has the 10 speed transmission experienced this. It does this like 1 out of every 10 starts. And it also does it when your driving around and come to stop sometimes you will hear a thud and the truck will move a little bit.
2013 XLT 302A 145" Screw
Better take it in asap.
Reactions: Lisa_B
2017 XLT S-Crew 4x4
Mine does the same sometimes...
Seems like it could be kinda dangerous.
There may be a pending recall or TSB on this. Speak up to Ford, they may be unaware. Does it do it on level ground or a slight incline? I'm thinking it may have something to do with hill assist? Ask on the other Ford forums also.
Discussion Starter · #6 ·
Does it on my level driveway and even in the level parking lot at work.
Found this:
  • Some vehicles may rock or move slightly forward or rearward while in park at start up after cold soak. This condition may be accompanied by a clunk noise. This is a slight movement that is more often seen visually, rather than felt, when viewed from the outside and using the auto-start feature, if equipped.
Discussion Starter · #8 ·
Long story short, my truck has been broke since December 12th. Dealer has parts ordered. Computer wiring harness is burned up, needs a couple new sensors, and who knows what else they will find once they get it running so they can do the transmission checks. I'll keep everybody updated.
1 - 8 of 8 Posts
