1 - 2 of 2 Posts
I managed to get these installed tight behind the grille & just miss the shutters. They are a spot & flood pattern & as slim as I could find for a reasonable price but honestly the spot is barely noticeable compared to the high beam (high & low beams are standard housings with Led bulbs).
Definite improvement but a decent lightbar is still on the horizon.
I didn't remove the grille, these are quite lightweight & I had angle drills, angle drivers etc. Otherwise impossible without taking the grille off & apart.
High beam wire tap is still the same as old post I found for a 2013, sorry can't remember the colour but will check.
Sent from my SM-A705W using Tapatalk
2015 Lariat 4WD
Appears to be a clean install! Nicely done!
1 - 2 of 2 Posts
