I drive a 2014 F150 FX4 with the 3.5 eco, almost 90k miles. Catch Cans, CAC hole drilled.
I checked my oil which was all over the dipstick. It looked pretty low as best as I could tell so I added about a quart which brought it about halfway up the hash marks as best as I could tell. Even if it sits for a few days the oil seems to be all over the side of the dipstick no matter how many times I wipe and recheck, so I did my best estimation when adding the oil.
After I added some oil, I took it for a ride and somehow, my crankcase must have pressurized because I had my dipstick shoot out of the tube and oil sprayed all around the engine bay. I also noticed a ton of blue/white smoke coming out of the tailpipe and enveloping the truck. It smelled kind of like burning oil, but also like something else with it.
I took it to my dealership and they charged me $300 for an oil change, degrease, and to identify that the vacuum pump and timing cover both have slight oil leaks. They say that they tested it and that it is still making good power with no boost leaks or anything.
So I drove the truck over the weekend and noticed that I am still smoking excessively out of my tail pipe and starting to run rough at idle. It’s hard to get it to replicate, but I notice it at idle after it has warmed up and also when I am under load or accelerating up an incline. My girlfriend drove behind me and said she could smell the same putrid burning smell when I take off.
I took it back to the dealer again to actually investigate the issue and just got the truck back yesterday.
Now the dealer is saying that the right side turbo is making some internal noise when it starts to smoke, recommending a turbo replacement due to turbo seals.
They also said that oil is getting past the CAC, and recommended a new intercooler.
I knew about the CAC because I had the misfire issue pretty bad, and is the reason that I added the catch cans and drilled the hole - both worked very well. (There is some oil dripping from the CAC because oil got in somehow when it pressurized, in my opinion)
I’m stumped by this. It seems like it could be a PCV system issue? I put on the Mishimoto catch cans when I bought the truck in November. They have a check valve so it should have prevented the crankcase from pressurizing. They also seem to be doing a great job and the hoses all look clear. (Cans were filling up every 1500 miles or so)
I lost faith in this dealer after I was told that a slight external leak on the vacuum pump was causing this much smoke out of the exhaust. Now they are just trying to throw parts at it instead of identifying the issue.
Oil level seems to be stable since the oil change was completed after the dipstick blew out. I’m still getting blue smoke from the tailpipe.
This is my first post, but I’ve been lurking the forums for a while and haven’t seen a similar issue. Anyone have thoughts on what it could be?
