1 - 19 of 19 Posts
I have a 2018 RWD 3.5 ecoboost 10 spd looking to get a 32' tire. Was wondering if I might have to regear or not considering performance, mpg etc. Also will probably level the truck. I understand adding this stuff mpg will take some what of a hit but will it be because of my 3.55 gear?
32? Not too tall or too short.
That sweet 10-speed will hardly notice.
insert 32 foot tire joke here
Not sure what wheels you have, but trucks with 20” wheels come with a 275/55r20 which is a 32” tire. You shouldn’t notice a huge impact depending on what type of tire you are looking at. If it were me looking for a 32” tire, I would stick with something P rated for the weight savings over an LT.
I was actually looking at some toyos that are 275 65 18. They're an LT C though. I think they are around 50 pounds
50lbs per tire is not that large of a weight increase over OEM. You may lose 1-2MPG, but won’t notice a significant difference in power IMO. For what it’s worth, my last truck was a 2014 Gen 1 3.5 with 6 speed trans and 3.31 gears running 70lb 285/55r22 Nitto Trail Grapplers. I could get around 16-17 MPG highway depending on speed. Stock tires, I could get around 21mpg Highway.
I run 65lb tires on a 2014 with 3:55’s. I don’t think there is any need to regear up to 35’s.
This and this
I was extremely impressed with how the 10 speed handles bigger tires, I think that’s my saving grace when running 35 inch(load rating F) tires, I was expecting much more of a power hit off the line and a much greater loss in MPG‘s, seems like this 10 speed is a perfect match for bigger tires. I have 3.55 gears as well, 2019 3.5
Discussion Starter #8
Both of the toyo at3's im considering one is an E rated tire (275/70/18) and the other is a C rated tire (275/65/18) and both weigh around the same 50 pounds how does that even make sense? The E rated tire is even a 33 compared to the 32 inch C tire
Good question.
I am running 275/70-18 (E rated Cooper AT3) on the 6 speed transmission with 3.31 gears and I have no issues, even when towing. At the track, in 4wd, I can still get 1.90 sixty foot times. The 10 speed won't have nay issues with this tire.especially with a 3.55 rear end.
My '13 SCrew 4 x 4 came with 275/65 R 18s which are basically 32s. Had 3.5 Ecoboost & 355 gears. Plenty of power with this setup and good fuel economy. It also had a 6-Speed. Towed a 6000 lb. boat often with no issues. Currently has E rated KO2's on it.
Ecoboost Noob
There is a formula using the original tire size and gear ratio and then the new desired tire size to see if your gear ratio needs to be adjusted. Buuuut, I don’t remember exactly what it is.... 😳😬
Glad I could help!! 🤪
For a 3.55 gear ratio truck, i use and recommend the continental terraincontact AT. this is an outstanding tire in 32" and 33" size, very lightweight and excellent road manners in all conditions. i dont know or like anyone or anything else about continental, its just a really good street tire in this size range
Discussion Starter #14
Kinda going in a different direction with this but if im leveling my truck I might want to gain a little rake back with the level should I go with the aal or block? I dont tow too much but I dont want my back slouching down whenever I add weight back there if I add a block.
That’s exactly what I did with my old 2013, I leveled the front with Bilsteins Then I replaced the rear blocks with 3 inch rear blocks. It turned out perfect for my needs, I also hauled stuff in the bed a lot in that truck along with some towing here and there. The tires in this picture were just under 35 inch, also had 3.31 gears in this truck, 3.5 ecoboost
There are apps for this tire stuff -
Cooper Tires are just about the best there are and made right here in the good ol USA, my good Patriots.
1 - 19 of 19 Posts
