41 - 60 of 66 Posts
· Premium Member
It's actually beautiful.
But it co$t a small fraction of what I would have expected for a 400 cell cat.
How is that possible?
2016 Ford F-150 XLT 2.7L
I think for the next one, I'll center it with a couple pie cuts. Call it an inspired idea 🤣
@boostkingMatt these are designed to mate up with my flanges 😉. But I suppose I could modify a downpipe of any type.
Heck yeah. I’d seriously like to see how yours goes and what it sounds like. I want to see if the 2.7 will sound like a Nissan GTR as well.
2014 F150 Supercrew longbed - 370hp, tuned it myself
Discussion Starter · #48 · (Edited)
Upcycled a Honda halfshaft into a flaring tool. The process needs some refinement to be sure, but it moves 304 like it's not even there. I think the biggest issue is my crappy HF saw not cutting straight 🤣.
The Vibrant 90° elbow wasn't polished like I was hoping, so I guess I need to do that as well, so it discolors evenly with the rest.
Wood Gas Auto part Automotive tire Automotive wheel system
Hand Gas Household hardware Auto part Wood
Discussion Starter · #51 ·
I need some pictures of firsthand experience here... The loop is 9" across, so I'm trying to figure out the bast way to clock it. Since I won't take my truck apart until everything is ready to go on, I can't fit it to my truck at this time. How much room does one have around say an AMS or FullRace downpipe? I can free up a couple inches with the tiny cats but I don't know if it'll be enough.
What does the loop look like now?
Same as what I have pictured, I just need to find a good position to put it before I weld it all together.
Ok checked it out sorry lol, what if you take a 1/2” out of the throat of each elbow to shrink it in size or would that effect the equal length that your trying to do?
Discussion Starter · #56 ·
Pipe expander and air-over-hydraulic pump came in. The manual pump doesn't move stainless that well, and I don't have the fittings handy to make the connection, but at least I have it all 🤣
Motor vehicle Yellow Automotive engine gasket Tool Automotive exterior
Next up is the polishing progress: this is after 600 grit
Wood Gas Hardwood Auto part Bumper
And this one is after 1500 grit.
Wood Table Natural material Hardwood Gas
Tomorrow I'll hit it on the buffer and see how it shines up from here.
To get a pretty good shine you could have stayed at 600 or go up to 800 grit. Remember to use green buffing compound for stainless
Discussion Starter · #58 · (Edited)
Ordered gaskets from 5*, along with the rest of the tubing. Once that all gets here, I have 2 weeks to get the pipes installed and figure out the Y pipe.
The Vibrant 90 shined up pretty good with whatever was left on my wheel.
Motor vehicle Automotive tire Hood Bumper Automotive exterior
Drivers side started as a result. This is the easy side, mind you.
Wood Motor vehicle Gas Bumper Auto part
Wood Motor vehicle Steel casing pipe Gas Engineering
And welded the loop up. It's not attached and the long end is just tacked as well, because I still need to figure out the merge.
Beige Jewellery Body jewelry Wind instrument Metal
Discussion Starter · #59 ·
I was stressing trying to figure out how to connect the air-hyd unit to the ram.... Then I remembered that I knew how to use a lathe 😁. This started as a 3/8 ORF with an OD that was too large, so I turned it down and cut new threads... Considering what I'm working with, this turned out pretty good.
Finger Gesture Thumb Nail Automotive tire
· Premium Member
F150eco zl1, trans am , Malibu, looking for a kids first car
The craziest thing just last week I was watching a video of F1 V12‘s sounds from the 1980’s- 1990’s and that sound comes from equal length perfect headers , it made me think if it was possible to generate a better sound after the turbos by building crazy long length down pipes and exhaust ,which split into a 2-8 -2
hopefully by splitting the exhaust from 2 pipes which are 3 or 31/2 inch pipes down to smaller diameter 11/2 inch pipes which are not really equal length ,but built in a way that fakes how equal length pipes act allowing the gases to hit the collector in a firing order giving it that roaring sound..
I know this may just turn it into a terrible sound while causing droning at different RPMS , but u less you experiment you never know..I tried looking around the Internet and couldn’t find anything close to it being done before,, maybe there’s a reason,lol..
41 - 60 of 66 Posts
