1 - 6 of 6 Posts
I wanted the change out the FX4 sticker on 2016 Platinum. I know a lot of people prefer the clean look with all of the stickers removed. I went with a darker sticker on dark truck. There are many options available on After Shock Decals and their image quality is top notch. I went with the Black Carbon Fiber with Red Accent. From a distance, it has has a clean look.
163016
163017
Looks good
What process did you use to remove them ?
I’ve thought about removing the FX4 on my white CC
-Brian
Heat (hair dryer or heat gun on low setting) then peel away. Afterwards you can clean with WD-40, lighter fluid, alcohol to get the residue off then wash and wax the area for protection.
That’s what I thought
Thanks
-Brian
Took mine off, on every truck I have owned.... they come off super easy....... and the look to me is 100% better and cleaner!!!!
I removed mine today . I also installed an FX4 emblem
-Brian
1 - 6 of 6 Posts
