Waste of money from what I've read.I am on the fence with purchasing. I read there is no tuning needed, however I have GH Tuning. I see it says it greatly improves throttle response with small HP and TQ gains. Can I get some feed back?
I have spent every minute since my post researching, your right. Not for me at this time.... ThanksWaste of money from what I've read.
Please do!I ordered a ported throttle body 69mm on eBay. I’ll let you know how it goes on my 16’ 2.7l
3.5 ecoyou don't state what engine you have. That may offer other alternatives.
But only if you have done virtually every other modification available and have too much money burning a hole in your pocket; then you may want to check out a tb. I personally think tbs and cais should be your last modification. and depending on your engine, you may already be at it's maximum threshold.
Tbs give very little hp for the $ spent.
Maybe so, but I’ll take everything I can get with a bolt-on on this 2.7L. More air can’t hurt it.
Do you sell muffler bearings too!?I have some stickers i can sell you. They are good for at least 10hp each. Just send me cash via mail.
Don't do it man, the weight of the stickers added will kill your 1/4 times!I have some stickers i can sell you. They are good for at least 10hp each. Just send me cash via mail.
I thought I had the part about N/A vs Turbo differences for TB (and other mods BTW), but you said it perfectly - and something guys need to understand. The way a N/A, Roots type and centrifugal type power adder works with various mods can be quite different. And sometime detrimental too.On blow through applications such as a twin turbo set up, the throttle body does not normally become a restriction until much higher airflow levels are reached. The turbos can PUSH the air through the throttle body, more effectively than say a draw through system (roots blower) would do when trying to SUCK through. Differential pressure and such.
Point is, as I've said in the past, you likely will see very little to no benefit of a throttle body until you are at 500+whp or even more. Dont waste your money. They are a pain to tune for almost no gain.
If your truck is making stupid power, go for it. Otherwise just leave it.
On a past N/A car I had when I went to a larger TB, I did get some mid-range HP/TQ but it was less than a 2% gain - and I had to tune it too to work right. I found using %Gain the best way to measure many modifications.
Often Manufacturers will use a 600HP car, get a 2% gain and then advertise ONLY the 12HP increase from the mod. Plus they neglect to mention all the tuning you should do to optimize the modification (especially if you have a Speed Density type EFI). But when you only have a 270RWHP (like most of our base Gen 1), it becomes only a 5RHWP gain (and only when optimized). Without ANY tweaking of the tune, you may even find you loss HP.
And then you have cat-back exhaust, where bigger isn't always better. Louder, yes. But better, not always.
