1 - 9 of 9 Posts
Hello.
Recently my 2011 Ecoboost FX4 has felt like it’s stuttering when I accelerate then at the top of the acceleration it feels like I lose all boost. Plugs have been recently changed. I’ve owned the truck used for less than a year now at it’s completely stock. I want to see if there’s a quick fix here before I have to go to the dealer.
thanks
Welcome to the forum ! You have come to the right place 👍🏼
Do you have a wrench symbol on the dash display ? Have you checked for codes ?
Just checked the air filter and map sensors everything looked good and clean. Any other ideas
Sounds like the issue I'm experiencing. Probably condensation or oil in your intercooler, try the weep hole see if it helps. For your sake if anything drains out I hope it's condensation and not oil.
Discussion Starter #8
Update...
So I’m thinking it’s just condensation. As I had went to the carwash the day before and used engine cleaner, then sprayed it down perhaps just some water in the inter cooler. Can’t replicate what was happening.
Be sure and do weekly Italian Tuneups.
1 - 9 of 9 Posts
