1 - 2 of 2 Posts
I have a brush guard on my F150 and want to put fog lights on. My question is can I wire the lights directly into the running lights using the fuse and relay and not putting the switch in the cab? Thanks
If you're getting rid of the factory fogs and assuming the aftermarket units aren't higher current than factory, yes. Otherwise, you'll need to run a relay.
1 - 2 of 2 Posts
