1 - 18 of 18 Posts
I recently purchased a 2019 sxt super crew with 2.7 ecoboost. It has the heavy tow option prewired for trailer brakes but no controller. I have read and heard conflicting stories about installing one and programming the computer. Etrailer says you don't via their tech staff. I have read both on here. Some say you do some say you don't. I could care less about the anti sway option in the truck since my load distribution hitch has one. So what's the truth about programming and using a p2 controller?
Couldn't care less...
But you will have to turn on the factory brake controller and that can be done with Forscan. To use a P2 you can use the pigtail and should not need to program it.
I have the same controller and it's been working good. No other programing.
Once you installed the prodigy, you did not have the computer flashed to acknowledge it?
I didn't. I didn't know I had to? When I apply the controller brakes manually, they work.
The P2 doesn’t require any system updates. Only the OEM controller will require updating the system so it interfaces with the truck.
Yea, I don't think that the folks who haven't seen the "integration" of the Ford brake controller realize how that differs from the traditional add-on brake controller.
There's something really cool about touching your controller and seeing the feedback on your OEM dashboard display.
The P2 is a nice controller but I do agree with this! Having it all integrated sure is nice; and it works correctly!
But, to be honest, if I couldn't get an integrated I would stick with the Prodigy line, preferably the P3
I ran a prodigy in my 2009 and integrated in my 2016 that came with it. It is very convenient to have the integrated, but properly set up, the prodigy stopped the trailer almost as well as the oem.
Do you have HPP or Max tow? Cant have the Max tow with a 2.7L, and the Max tow would have a controller built in from the factory. The HP would throw you to a 5.0L.. So maybe you have just the regular tow package. Make sure you know your tow limits.
If you ordered the Max Tow it would have come from the factory with the controller. You sure you actually have the tow package?
There are 2 towing packages available with the 2.7. A basic package has the class iv hitch and 7&4 pin connectors and the better one that EDITED: also does not include the TBC.
To add the OEM trailer brake controller you need to make changes to enable it by either having the dealer do it $$ or by using Forscan on your laptop and making the changes yourself.
Go here to learn everything you need to about Forscan.
Edit: Link to video for TBC install
The "better" tow package still doesn't include a brake controller. I got my truck with the tow package (53a package, step up from class IV hitch which is 53b).
My truck did not have a brake controller.
Hmmm My mistake. After checking I also have the "upgraded" 53a tow package. Looks like the TBC only comes with the Max Tow package that also requires the 3.5 Ecoboost.
I will be adding the TBC on my '16 XLT 302a 2.7eco this year and enable it with Forscan. No dealer fees for me. :)
I had the 53a package also. I bought the brake controller for about $100 and paid my dealer $100 to install and flash. Well worth it!
1 - 18 of 18 Posts
