It is 4wd, reason I think it’s leveled is because it sits higher than other stock f150s, was wondering if it’s possible to see the spacer, only other picture I have at the moment is this oneSpacers are far from the only method of leveling the F150 front end.
Is it 4WD? Can you get a shot from the front of the CV angles?
When I look at wheel well height it definitely looks higher than stock trucks. Was more just wondering if you can see the puck/spacer in there or not. Also is kind of hard to judge because the truck came with 33s on it when I purchased it usedMight be a dumb comment but from a distance does it look level?? Can you compare each wheel well height with another truck that you know is not level?
When I look at wheel well height it definitely looks higher than stock trucks. Was more just wondering if you can see the puck/spacer in there or not. Also is kind of hard to judge because the truck came with 33s on it when I purchased it used![]()
Judging by the angle of the upper control arm, though, my thought would be that it is leveled.I recently bought my 2017 XLT 3.5 and cannot tell if it is leveled already, is there any way to see if there is a spacer in the suspension while it is on?
