Show us where Ford is actually recommending this as a fix?
Show us where Ford is actually recommending this as a fix?I’ve only had them for a few months, but they work well. Ford is now recommending to do a vacuum delete anyway, if you’re out of warranty. Sent from my iPhone using Tapatalk
You remind me of myself with technical knowledge.![]()
Ford TSB 22-2219 IWE Delete for Lariat +
Well they finally called for it? Ford officially recommends removing vacuum for 4A trucks?www.f150ecoboost.net
I am have the Delete kit that TED BRITT FORD put on there because they couldn’t figure out the issue. (Change the hoses out, replace the whole system then). By the way did I mention I was under warranty as well? Less than 30k on the thing. So back to the story. I wouldn’t mind having the IWE delete kit if I didn’t hear the front drive assembly moving. It’s a faint winding noise. Also lose amount a mile per gallon.![]()
I'll take this as a compliment, right?You remind me of myself with technical knowledge.
Here is a link to the TSB. Ford does recommend it. You can see where they say to remove and cap the vacuum line. That leaves the IWE's engaged.I am have the Delete kit that TED BRITT FORD put on there because they couldn’t figure out the issue. (Change the hoses out, replace the whole system then). By the way did I mention I was under warranty as well? Less than 30k on the thing. So back to the story. I wouldn’t mind having the IWE delete kit if I didn’t hear the front drive assembly moving. It’s a faint winding noise. Also lose amount a mile per gallon.
All of my fords have made that noise in 4h or 4a. Also when in 4a, it stutters when accelerating. I remember my explore doing that, but that was 98 and considered normal.
I really don’t see how ford recommends a IWE delete. Ford would never recommend this. FORD not the ford dealer.
It’s in the shop now for its 2nd transmission installation, inner-cooler also bad, I am pretty much making them change out the whole IWE system. I don’t want it back until they do
I believe stock is full syn in the rear already. Front is not.FWIW, I did not notice any drag reduction after switching to synthetic gear oil when I serviced the rear diff. I was a bit surprised since I have noticed improvements on my other cars.
