Yup cheapest I can find Timbrens is $250+ tax.Ohhh Cannnaaaaddaaaa!
Airbags were $450+tax and that doesn't get you any more than the manual set up.
And for the 10 times a year I tow the Timbrens will be perfect.
So if mine are 8.25 inches from frame to axle if you used the spacer that’s 9.25 inches. If you got a longer bolt I could send you the spacer I didn’t use for my truck that I think would give you the right amount of clearance?Okay so from frame to bump stop wing plate is 7 3/4" from frame to axle is 11.5"...
Hmm.
I can find all sorts of spacers at work. Work in big steel mill! Thanks for the offer. So what I will do is just cut the wings off the blocks with the sawzall and use the spacer x 2. Or weld a 1" perch to the top of the axle just use cheap trailer axle perches.So if mine are 8.25 inches from frame to axle if you used the spacer that’s 9.25 inches. If you got a longer bolt I could send you the spacer I didn’t use for my truck that I think would give you the right amount of clearance?
Add a leafs will be stiffer than I want.You're probably too far down the rabbit hole and looks like Timbrens will be a goof fit, however... What about going to a 2 inch block and adding some AAL's?
There is one negative thing I've heard about Timbren's, it's that when going over moderate bumps, it can be jarring when they make contact.
Can confirm the jarring - I only notice it under “moderate” load. If I’m driving empty no problem at all. If I’m driving with enough weight there is constant contact no issue. But that intermediate weight can be a bit unpleasant.You're probably too far down the rabbit hole and looks like Timbrens will be a goof fit, however... What about going to a 2 inch block and adding some AAL's?
Are you at the 1" or 1/2" gap between jounce bumper and axle?Can confirm the jarring - I only notice it under “moderate” load. If I’m driving empty no problem at all. If I’m driving with enough weight there is constant contact no issue. But that intermediate weight can be a bit unpleasant.
BUT I also often times forget to air back down my E range KO2s after towing so that also contributes
To be honest I don’t remember for sure. I carry enough tools as such in the truck I would assume I was closer to the .5. I don’t know if my truck has been empty since I brought it home lol when I measured the other night it was sitting on the axle, we had are expecting snow so I have some sand bags in the back.Are you at the 1" or 1/2" gap between jounce bumper and axle?
