I was able to get the Bambi Mod working on my 2013 F150. I would think it should work on 11-14 models. 15-up is not the same line.
FYI, Bambi Mod is the ability to keep the Fogs on when using highbeams. Obviously, if your truck doesn't have fogs from the factory, or if you haven't pulled your switch out to enable the fogs, this will not work.
If you are not a Forscan user, there are lots of threads with info on that, and you will need the extended license for the change.
As always, it's a good idea to save all your original abd files before making changes.
Anyway, in the BCM AS-BUILT,
Line 726-11-01. If your shows 0301 in the first four digits, change it to 0302, then write. Leave all other digits the same.
It's gonna tell you there is a checksum error, and ask if you want to continue. Click yes. Then it'll tell you to cycle the key to OFF/ON. That's when it applies the change.
If that doesn't work for you, then revert the number back to original. As always, like doing anything of this nature, you assume all responsibility of possibly messing up your truck.
Good luck and report back.
