Bed Lights?
14K views 32 replies 20 participants last post by  TexMex
#1 ·
Has anyone installed bed lights in their truck? I'm curious about where to start looking for a power source. What have you done?
I picked up a couple of items from amazon and plan to install some bed lighting and an auxiliary backup light.
#2 ·
I ran power from the front battery all the way back, it was much easier and now I have a 12v in the rear for all my needs. I have the switch on the right side and was just a left over toggle I had sitting around. This has to be one of the best mods I have done to date, very functional and after I did mine I did my dads 350 also.
#5 ·
Sounds like running power from the battery is what everyone is doing.
I have a 15' roll of LED lights, and a remote controlled 2 channel relay. I plan to wire the bed lights to one channel and a reverse light to the other channel. I'll be able to turn them off or on from anywhere around the truck with the keyfob.
At least that's the plan....
#9 ·
I installed 2 KC cyclones with a switch. I actually pulled my 12v from the trailer harness. I put the 30amp fuse in the engine bay fuse box and then made a jumper to jump the relay terminals so the 12v is on all the time. I also have 16 feet of LEDs mounted on my soft cover that run of a rechargeable 12v battery. The last pic is just the cover lights since the KC lights weren't installed yet.
#11 ·
I did something similar to what others have done. I just used 4' LED light strips with a rocker switch in one of the holes already in the right side of the bed. I ran the hot wire to the battery with an inline fuse right at the battery and grounded to the frame at the back of the truck. This way I can have the lights on regardless if the key is on or not. This setup works well for me because I lost the cargo light when I had my tonneau cover installed.
#21 ·
Eventually i'll get a nice camera, and a hexa-copter to mount it to, for awesome aerial shots.
#23 ·
I used the heavy duty 3m double sided tape after cleaning the surface good. I think gorilla glue makes some too, and if you have a Bedliner don't cheap out on the tape. You will have to watch it for a while after install to make sure the glue has a good chance to stick.
#29 ·
oh boy that is huge!!!! "thats what she says"
Sorry for both.
Reactions: agentjohnson
#30 ·
Nice pics! gonna have to look into this. Much better than my flashlight app on my I-phone.
#31 ·
I went the slightly more expensive but completely less permanent route and picked up the battery powered 18" strip from Truxedo:
B-Light
One is enough light to illuminate the entire bed area under the cover. Two would be an awesome amount of light. Double sided tape and a plunger switch on the battery box. Perfectly sufficient, not overkill, and won't drain the battery if I accidentally leave it on.
Reactions: mc4100s2
#32 ·
#33 ·
I bought a set of bed lights at auto zone and wired them onto a system that takes two 9V batteries. I used a plastic waterproof cigarette case you can buy at Academy to house the components, drilled holes for a few wires and a switch then mounted it near the tailgate. Have had it for about a month now, works great, no issues (I have a bed cover thats almost waterproof). I don't have to turn the truck on for it to work and like MCDavis said, I don't worry about the battery on the truck draining. Have pictures on a home computer if someone wants to see the ******* innovation.
