If your looking for all the details and spec on the BFGoodrich All-Terrain tires, check out this link to Tirerack and click on Specs:
BFGoodrich*All-Terrain T/A KO
good point I forgot. Max on the 10 plys was 80 and I ran them at 65 empty and bumped them to 70 towing and got very flat wear out of them.I have always been told to run max tire pressure or near max tire pressure when towing. This last trip out I had my tires @ 50psi (max is 80) and I think it actually towed better. Sometimes running near max tire pressure the truck seems more over the road.
I'm currently running BFG All Terrains 275/70/18.
Width - 7.5"
BS - 5.5"
44mm Offset
Bolt pattern - 6x135mm.
Now the Problem..Nitto Terra Grapplers LT295/70-18 or BFG LT305/65-18 or Goodyear Duratrac LT295/65-18.
Aloha STDan, not yet. I will probably run down the stock Wrangler SRA 275.65-18, until the end of the year. The only tire that currently fits my wants is the Wrangler Duratracs. Kinda been getting mixed reviews of them online. Maybe by the end of the year there will be a better selection of tires. Spent the day putting on the Ecoboost front license plate relocate kit, Go Industries 32639 Quad Push Bar, and Anzo 111263 headlights.Now gotta fingure out how to mount the front license plate, required by the lovely state of Aloha.
Do you have a suggestion for radial, all terrain, LT295/65-18?
