So, I was talking to a friend about his Fusion Sport and I looked at CRPs website for the fusion turbos and I realized they have a stage 3 upgrade for the MKZ and Fusion that has a 46mm compressor wheel and stock turbine though. I already shot an email to Andrew at CRP about seeing if I can throw that 46mm compressor on my larger 45mm turbine and then just get compressor covers milled a bit larger for the 46mm. Anyway, it’s always a quest for bigger and better!
Only reason I’d consider it is they technically would be a tad bit more efficient, and I’d be able to run a bit less boost probably and they’d be louder. 😁 If that in and of itself isn’t reason enough. Haha
