1 - 9 of 9 Posts
Hey All,
New to owning a truck. Have always had cars or jeeps before. Have a roof rack on the car and had hitch racks for the jeep but didn't want either for the truck. Bought a Dakine Tailgate pad but didn't want to use it unless I was shuttling.
Hmm whats a guy to do.
I seen a post somewhere where one fastened fork mounts directly to a hard tonneau cover. However I didn't want to drill into a new $1k cover, nor did I think it would support the uplift.
Another consideration was to install BackRack Siderails and weld a bar to either side parallel to the back window. Then I'd have a spot for the fork mounts. Seemed a little costly and didn't like the look of those particular siderails.
While looking over the install for the siderails I thought, why don't I bolt a bar via the stake pockets. Then quickly picked up some supplies.
67 1/2" HSS (1 1/2")
2 Stake Pocket Anchors (Toss the anchor)
Additional nuts and washers
End caps
Fork Mounts
And this is the end result>
Looks good.
I'm the one that drilled holes in a perfectly good Bakflip F1. :cool:
How's the fiberglass holding up on the F1?
any details on how you mounted the bar to the anchor points? :D
I'll get more pics. But I basically drilled a 3/8" hole into one wall of the HSS, 3/8" from each edge of the bar. Dropped the bar onto the bolts rising up from each stake, then used a racheting wrench to fasten down a nut.
Haven't had any issues, but the mounts sit atop a 48" by 2" by 1/8" piece of aluminum flat bar. There's one on the bottom of the panels too.
I did increase the size of the washer at each mounting point where the fixed panel is through bolted to the rails just for extra piece of mind.
This is actually my second F1 (first one replaced under warranty due to workmanship issues on the tailgate panel) that I have implemented this mount upon.
Banned
2020 Ford F-150
Hey All,
End caps
Fork Mounts
View attachment 69249 View attachment 69257 View attachment 69265 View attachment 69273
Are bike racks universal? Do bike racks damage your car🧐 🚘 🚲?
1 - 9 of 9 Posts
