1 - 6 of 6 Posts
I Have a 2011 lariat ecoboost. I've replaced the blower motor resistor three times in the last month. 1 motorcraft, 1 china knock off, 1 dorman resistor. I have dual zone and blower mode stays on HI after failure. Any thoughts? Maybe the blower motor is going bad causing the resistor to fail at low speeds?
You somehow have water draining into you air box?
Have you checked the wiring on the pigtail? I know you can get the pigtail with it in case it's burnt up in the connector.
I would think the motor has some shorted windings and is drawing more current than the resistor pack was meant to handle. Change the blower
Checking the connector next the resistor is exposed to condensate inside the air box naturally and it seems to be draining fine.
Thats what im starting to think hate throwing parts at it but why not its going to eventually need 1
1 - 6 of 6 Posts
