1 - 4 of 4 Posts
2011 150 ecoboost, BOTH heated seats not working. Switches light as normal, replaced both fuses, even replaced battery as a test showed it was bad bit nothing on either heated seat. Is it worth replacing the TED unit? Just can’t believe both heating elements failed completely.
Odd that both would go at the same time. My driver side seat did the same thing, light was on but no heat. The power wire that ran up the back of the seat was broke. Lucky for me it happened while still under warranty. They had to remove the seat and leather upholstery get to the wire then re-skin it. I'm sure it's costly!
Same problem here. Dealer said its an interface issue and will let me know next week when they can fix it. i will let you know later what they came up with.
1 - 4 of 4 Posts
