Just installed the bumber grille on my 2011 Eco boost F150, took about 15 min. the grill I ordered from amazon (around 41 bucks) very easy to put on. I didn't use the hardware that came with the grille, there were two #8 screws and two spring nut clips. I found it was going to be quite hard to get a stubbby phillips down in there to tighten those screws. I drilled out the mounting holes to accept 1/4 X 3/4 Hex head bolts with hex nuts & flat washers. pretty easy to tighten with a 1/4" drive ratchet (7/16 Socket & 7/16 open end wrench.) Well pleased with the look, gives the front bumper a finished look.
