2017 F150 3.5 ecoboost, 116000 miles. Cam phasers again. Replaced at 31,000 miles, 72,000 miles (New style phasers, timing chain and guides, water pump). Noise is back at 116,000 miles. would an oil additive help.
I’m of the opinion it helps- my auto stop has been disabled since right after my cam phasers were replaced.I don’t know if this has helped me but I disabled auto start/stop a while ago. I don’t regret it. I think it saved on start up wear.
Less chance of damaging the phaser locking pins.I’m of the opinion it helps- my auto stop has been disabled since right after my cam phasers were replaced.
I doubt the dealer disabled that. Could have, but I’m not sure why they would. Is your battery good? Low battery conditions can disable the auto stop.Hum, I also noticed my auto stop is disabled after habit my phasers replaced last month. I wonder if my dealer disabled it? I always thought that auto stop feature was a bad idea for starters, as well as damaging some other engine component.
Do you switch to Sport Mode when you get into the truck? That disables auto start stop as well!Hum, I also noticed my auto stop is disabled after my cam phasers were replaced last month. I wonder if my dealer disabled it? I always thought that auto stop feature was a bad idea for starters, as well as damaging some other engine component.
I miss my Tacoma. It was an awesome rig and only needed maintenance as well.I'm going with the fix, them maybe trading. In addition to the 3rd time replacing cam phasers, I've had the APM replaced, oil pan. Also this 10 speed is the worst shifting transmission I've driven. I'm considering trading for a Toyota. My wife's 2 Toyotas since 2007, have only needed oil changes.
Interesting. And I am NOT against the Lucas oil treatment necessarily.Noise at 119000 change to 10w40 w/quart of lucas oil treatment, no more noise...
Someone with the clatter needs to try either of those.Interesting. And I am NOT against the Lucas oil treatment necessarily.
But I'd love to know if just the oil viscosity change might have quieted things down alone?
I don't know how he could?Do not know if its the oil or the Lucas, but happy that they are working together.
I bought a 1995 and it was a beater. But only I ever did was an exhaust manifold. It ran awesome and never failed me .I don’t miss my 07 Tacoma. It was not trouble free, 4 rear axle seals in 120K a frame that looked like a piece of interior plywood left out in the rain, the brakes with the 1970’s drum in the rear never felt like they wanted to stop the truck like as not very linear in braking force. One front wheel bearing (they aren’t cheap).
Yes!It seems like it makes sense to replace the water pump at this time. No extra labor charge by the dealer. Just the parts. Does this make sense?
Thanks
Mike
Great idea to replace a wear item at only parts cost.Just dropped the truck off and they verified the phasers they have are the latest version.
Thanks
Mike
