1 - 1 of 15 Posts
hello, did you fix your problem? I am having the same issue
Boys and girls lol I’m in desperate help. My 2011 f-150 eco boost won’t stop kicking a code “p0394 cam shaft sensor bank 2 sensor circuit intermittent” sooooo I’ve replaced all sensors, solenoids, sensor harness, fuse box harness pcm, cam phasers and timing chain. It’s getting really old fast. But after everything it starts but runs, it starts but falls on its face really fast and turns off, if I put my foot on gas it won’t turn off because it’s running rough but it will still run really ruff and have very little power to none. I’m just wondering if there is a sensor or something that could go bad that tells the cam sensor to to tell the tensioners we’re to go. Or maybe someone knows what mite be wrong I’m in desperate need of my truck back it’s been way to long and dumped a lot of money into it and nothing fixed it. Idk I was reading about toner rings but maybe something else it could be that would be a more logical answer anything will be appreciated. Thanks
1 - 1 of 15 Posts
