41 - 45 of 45 Posts
Also makes me wonder how much of the load is pushed forward to the front axle with a weight dist hitch ???
The amount of weight transfer is typically adjustable on the better hitches. You can transfer as much as you want, however you should never transfer so much that your rear axle weight is too reduced. This will create a very dangerous sway situation. One thing to keep in mind with toy haulers, typically the weight is in the rear, even though this adds to the trailer weight, it actually reduces the tongue weight because it's pulling UP on the tongue. It's a large lever. This needs to be taken into account when dialing in the WDH. I suggest using a Sherline tongue scale to get an approximation of what you're dealing with, especially if the load or it's distribution changes. Once you think it's distributed well, take it to a CAT scale and get more accurate numbers.
172722
2020 F-150 STX 4x4 Supercab
I used to have similar issues. Spent a lot of time and money to no avail. I did finally find the absolute perfect solution…traded for an F250!!!
2013 XLT 302A 145" Screw
Leaning heavily toward that myself !
We need details and photos.
41 - 45 of 45 Posts
