Not all E85 is actually 85. My station varied between E76 and E80...... I have seen it as low as E68 So your calculation would be off....... you need to text to content of the fuel every month, minimum.... plenty of apps avail that make this a pretty user friendly process.Octane-rating (AKI, not "octane") mixes linearly same as the equations I posted earlier.
Lets assume E10 and E85 really are 10% and 85%. Correct the numbers based on your test results.
I don't see AKI listed on E85 pumps around here but most references say 104 AKI if it really is 85%. It might be 100 AKI for lesser proof.
To mix E10 and E85 for E30:
0.9 gasoline + 0.1 ethanol + X * ( 0.15 gasoline + 0.85 ethanol ) = ( 1 + X ) * (0.70 gasoline + 0.30 ethanol)
After much fun math: add 0.364 gallons of E85 to 1.0 gallons of E10 to make E30.
A = 0.90 for 90% gasoline in E10
B = 0.15 for 15% gasoline in E85
C = 0.70 for 70% gasoline in E30
( A - C ) / ( C - B ) = ( 0.90 - 0.70 ) / ( 0.70 - 0.15 ) = 0.363636363636364
1.0 gallons of 87 AKI plus 0.364 gallons of 104 AKI E85:
(1.0 * 87 + 0.364 * 104) / ( 1.0 + 0.364 ) = 91.5 AKI
Some say E100 is 107 AKI and 85 AKI is the base gasoline used. That produces 87.2 AKI for E10, 103.7 AKI for E85, 91.6 AKI for E30.
87 AKI E10 needs 84.7 AKI E0
89 AKI E10 needs 87.0 AKI E0
91 AKI E10 needs 89.2 AKI E0
93 AKI E10 needs 91.4 AKI E0
