1 - 20 of 31 Posts
Here at RDP Store we don't bump just to bump the thread. WE on a daily basis upload new products everyday. So many new products to advertise individually we just can keep up. Stay tune to this thread for Daily specials on the products you may want for your ride. So don't for get to check us out, there is always something new at RDP Store and always a promo code to help you forum members to save big. Take a browse and PM us today if you see anything that peaks your interest and if you don't let us know and we will find it for you. We can get all the part you need and all the name brands. Suspension, exhaust, programmers, wheels, led lights, floor liners, bed covers it goes on and on. PM us today
http://www.rdpstore.com/default.aspx
RDP Store has been partners with Aeroforce for years and they have an amazingly capable unit that just plugs right into your OBD2 port, install is a breeze. PM uus today for special pricing on single or dual units and different mounting locations. But check out the features below.
http://www.rdpstore.com/p-499-aeroforce-interceptor-gauges.aspx
The Interceptor scan gauge is capable of displaying over 100 parameters, two at a time (8 using cyclic scan), at an adjustable rate of up to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this and make it available for display. A sample list is below...
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
2 user configurable analog inputs**
** 0-5v inputs can be configured to read the outputs from MAP sensors, Air/Fuel ratio kits, pressure or temperature sensors, etc. Raw voltage can be displayed or a conversion can be entered to read proper units.
Users will find that ability to log RPM vs other parameters at high speed such as ignition advance, boost, or knock retard invaluable with regards to tuning.
aFe Power has the most killer cold air intakes on the market today. RDP Store has done side by side comparsions on our in house dyno across differ brands of cai's and different makes and models of vehicles and aFe has been coming out on top they flow so good......check them out today and PM us for any detials and special forum member pricing and as always at RDP Store get free forum member shipping
RDP Store - AFE
RDP Store is proud to offer the high quality Spyder Auto for your rig. Spyder Auto has an In-House visual graphics design team that helps develop their stunning lights. The quality lighting products offered by Spyder Auto are compliant with all applicable federal regulations. Unless otherwise noted, all products are D.O.T. Compliant and satisfy Federal Motor Vehicle Safety Standards (FMVSS) code no. 108 and are not only ISO-9000 certified but also ISO-9002 certified as well. If you have any questions or dont see what you are looking for PM RDP Store today for details.
RDP Store offers the SuperChips 5845 HP Tuners vessel.......The Flashpaq F5 Pro from Superchips takes our latest and greatest platform product and turns it into a vessel for loading custom tunes to your vehicle. Please note, this device does not come pre-loaded with any tunes. You can load up to 4 custom tunes from a dealer of your choice, using HP Tuners. I you have any more questions let us know and inquire about our special pricing for all forum members.
Specials on all Bed Rug products.......PM us today for your special pricing and free shipping for all forum members
Discussion Starter #8
RDP Store wants to remind you For a limited time, purchase an SCT tuner and get cash back! The company is offering up to $50 during their Tax Time Product Rebate on X4, Livewire TS+, and iTSX Gas/Diesel handheld Tuner products.
Send in your information to www.sctflash.com/rebate, or fill out the form below and mail it back with your proof of purchase and Bully Dog will send back a gift card. This is a limited time promotion that runs from April 18th- May 18th, 2017.
Rebate Details:
X4: $40
LIVEWIRE TS+: $50
iTSX: $50
Please include a copy of your invoice, a brief story or explanation of what the product has done for you, and picture of the vehicle with SCT badges or stickers to be used on social media.
Performance Parts Camaro Challenger Mustang SRT8 Corvette
Discussion Starter #9
RDP Store is now doing a Group Buy on B&M's brand new just release Transmission pan for 2009-2017 Ford F150 6R80 Transmissions equipped trucks. B&M’s Hi-Tek line of Deep Aluminum Transmission Pans are constructed of thick A356.0-T6 cast aluminum and feature a durable black anodized finished. These finned deep trans pans significantly increase the fluid capacity and dissipate heat much faster to prolong the life of the transmission and related components under standard driving and especially towing conditions. Additional features include an engraved B&M logo, drain port, temperature sensor fitting, magnetic drain plug and complete hardware and installation instructions. PM us today for detials and the group buy pricing, as always free shipping for all forum members.
2009-2017 Ford F150 6R80 Transmissions B&M Hi-Tek Deep Transmission Pan 70394
Discussion Starter #10
AMP Research products are available at RDP Store........If you are interested in their bed extender to all the different flavors of side steps RDP Store can get it at the best price you will be able to find anywhere. PM us today on what you are interested in and we will be able to give you a custom quote and as always free shipping.
Discussion Starter #11
Getting into your truck shouldn’t feel like climbing Mount Everest. That’s why AMP Research invented POWERSTEP, the automatic, electric-powered running board that instantly extends when you open your door, and then hides itself safely out of sight when the doors close for improved ground clearance, aerodynamics and appearance. Its handsome design, all-weather performance and legendary reliability set the industry standard. Ditto its industry-leading 5-year/60,000-mile warranty.
Discussion Starter #12
Save this month with our blow out specials for forum members and remember we always ship for free to the lower 48 states and ship for cost any where else in the world
Discussion Starter #13
Discussion Starter #14
Memorial Day Specials start Today for Forum Members Here, Let us know what parts you are looking for and we gaurentee to cut you the best deal period and we also ship for Free to the lower 48 states and cost price shipping anywhere else in the world, pm us here or give us a call on 440 358 5500 or 440 251 8571
Discussion Starter #15
BEDRugs on special now at RDP Store. PM us for details and the amount you can save today on these awesome new generation of pick up bed protections.
Discussion Starter #16
Discussion Starter #17
Memorial Day Sales Starting today, pm us here or give us a call on 440 358 5500 for a killer deal on anypart that your looking to get
Discussion Starter #18
Use the Promo Code of md10d for all your items at a Heavily Discounted Price for the Memorial Day Specials and get Free Shipping to the Lower 48 States as well.
Discussion Starter #19
Here at RDP Store we don't bump just to bump the thread. WE on a daily basis upload new products everyday. So many new products to advertise individually we just can keep up. So don't for get to check us out, there is always something new at RDP Store and always a promo code to help you forum members to save big. Take a browse and PM us today if you see anything that peaks your interest and if you dont let us know and we will find it for you.
Discussion Starter #20
1 - 20 of 31 Posts
