I have run edge 0w40 in my F150s since 2011. My 2009 5.4 3V loved it and so does my 2016 3.5 eco.
Looking for "Euro" spec'd oils has one advantage, a HTHS (Hi-Temp Hi-Shear Viscosity @ 150 C 1x10(6) sec(-1), mPa.s, ASTM D4683) test that specifies it stays above 3.5. What does that mean? It means when the oil is hitting cylinder walls, turbos and other areas that are higher than the average engine temperature, it's viscosity remains thick enough to keep metal to metal contact from happening. While many oils use additives to deal with this "boundary" lubrication area, but keeping parts spaced makes more sense.
Porsche A40, Mercedes 229.5, BMW LL-01 and VW 502 00/505 00 specifications are far more stringent than API SN, SN+ or even SP. The SP timing chain wear and LSPI are very rudimentary and even an SN euro oil has them beat by miles.
Castrol edge 0w40, Mobil FS 0w40, Mobil ESP X3 0w40, PP Euro 0w40 are all great choices and will protect your engine very well. As stated, 5k mile oil changes are still a great idea to reduce the soot load that builds up with Direct Injection engines, which also helps timing chains live longer lives. 5w40 oils can be very good too, but often contain less type IV or type V synthetic base stocks, which then require more viscosity modifiers to achieve the 0-40 cold/hot spread. VMs tend to shear and leave more deposits on valves in DI engines. Looking at an MSDS of the oil will often tell you how much type IV base oils are in the mix. Edge is between 20-50% (trade secrets mean they always show a spread), Mobil FS is between 10-20% and ESP X3 is 5-10%. Whether this matters is up for debate when they all meet the same specifications, but type IV PAO is more stable than hydrocracked type III.
There are plenty of great 5w30 and 0w30 Euro oils out there that also have HTHS numbers above 3.5 if you want to go that way.
Edit: There are plenty of boutique oils out there that use even higher type IV and V quantities, but generally cost significantly more. Amsoil Signature Series and Redline oils are some of those. Small oil blenders don't always apply to test their oils to manufacturers standards and simply state they "meet or exceed" some specifications. The oils above (and Valvoline, Havoline, etc Euro oils) are often available on sale and are economical for the average user.
