21 - 32 of 32 Posts
Yeah that metal gasket on the turbo with the crooked hard pipe is ridiculous. I bent the "flexible" pipe just slightly when doing a turbo removal and I couldn't ever get a proper seal at the turbo again. You change the angle and that pipe is toast.
The oil fitting in the block on my 2012 definitely has a screen in there. The replacement I bought had a little longer screen. I suppose the increase in surface area is supposed to increase available flow? Not sure if they are required, but I can imagine they are there to keep any sand/dirt particles from grinding on the turbo impeller shaft.
173282
2015 Lariat 4WD
Makes me wonder if mine were removed at some point, or if they are non-existent on the 15 models.
The G2 oil drain is a lot more flexible than the G1 variant. While they are both (I believe) stainless, the G2 is not connected to a plate in conjunction with the oil feed, so the distortion aspect is not really present. I did have to manipulate it a few times to get it to seat properly but once in place it was good to go.
On the G1 turbos, when I did my AN coolant conversion I did have some difficulty getting a good oil seal once I re-installed the turbo on the driver side. This due to the steering linkage making the angles all wonky when removing and then going back in. I ended up removing the line and getting the plate that connects to the turbo cartridge as straight as I could before I put it back in and it sealed.
Learned a good deal about the driver side in doing this, regardless of how many times one removes and replaces a turbo on these trucks, that side is always going to be more tricky.
13 FX2 SCREW
6X M14X1.5 6AN fittings (with o-ring)
2X M18X1.5 6AN fittings (with o-ring or hybrid crush washer)
6X 6AN 90 degree fittings
2X 6AN 45 degree fittings
4 feet of PTFE stainless braided line (you can use whatever you wish, I just opted to use PTFE.)
Is the oring required on the 14x1.5 or will a hybrid crush washer do?
I ask because I can't seem to find orb ones, but plenty with the hybrid washers.
As for the m18 ones, does the Saginaw type connection with the oring at the bottom work?
2015 Lariat 4WD
You can improvise with the M14's and put a quality o-ring on them. I will post some Amazon links of what works, standby...
As for the M18, no, I do not believe so.
2015 Lariat 4WD
You can go to a supply house such as Northern Tool, Lowes and even Harbor Freight and acquire a large o-ring kit that has oil/gas/heat resistant rings in all sizes. They are suitable for this application.
The M14's listed in the above link come with both an o-ring and a hybrid crush washer. I used the hybrid on the head location per the recommendation of those who paved the way before me. No leaks.
2015 Lariat 4WD
You are very welcome, if you need further assistance, please advise. This is a relatively simple project aside from getting the head fittings out.
Once you get the JT fitting clips off and the OEM coolant pipes out, its a breeze.
You got this!
I would think a crush washer would be mandatory on the turbos. Won't the orings melt with the temps they generate?
2015 Lariat 4WD
I thought the same thing, but if you recall, the JT fittings work based around an o-ring and while that is a poor design, there are trucks that have never had a coolant leak from the turbo fittings.
Prior to doing the G2 swap I had zero issues.
So I'm in the process of purchasing all necessary hardware to upgrade my turbos (going with CRP Stage 4). From what I've read it's a good idea to replace my coolant line parts while everything is off. My question is - should I buy the Full-Race upgrade kit? 2017+ 3.5L EcoBoost F-150 / Raptor AN Turbo Coolant Line Upgrade Kit • Full Race
Or am I fine just replacing OEM parts with OEM?
Hey OP, how did the FR line install go? I'm looking at replacing my lines and was a bit concerned with with fitment...
Discussion Starter · #32 ·
I had my local dealership install, along with the turbos and manifolds - they didn't mention any fitment issues.
21 - 32 of 32 Posts
