1 - 20 of 70 Posts
3.5ecomike
2019 f150 sc 4x4 full race exhaust manifolds, cvf intercooler,open up exhaust flanges, gearhead auto
Discussion starter · #1 ·
I have a 2019 3.5 EcoBoost starting doing some mods after I pulled exh manifolds off to bolt up full race manifolds I pulled my wires out the crankcase pressure sensor on drivers side that goes from intercooler tube to valve cover it has a yellow, yellow green ,and a green brown can someone please tell me when you look at yours plugged in from the firewall out which colors go where I tried many different set up and replaced the sensor and tube and keep throwing a p051D-00 code I thought i had it right we erase the code drive home fine shut off truck start it back up and the engine light comes back on. thanks for info I'm new to this site but not new to the EcoBoost.
Here is off of a 2018 wiring diagram. Hope that helps!
Discussion starter · #3 ·
I have this already sorry I didnt mention that my brother inlaw is a mechanic and gets me all this info I need to know where these go in the plug ?? How do they stack up Do you understand what I am saying ? Thanks
You ripped the three wires out of the crankcase pressure sensor? And want to replace them? But you already replaced the sensor too? I’m confused, sorry.
Discussion starter · #5 ·
I accidentally pulled them out they slide in easy I need to know from left to right or right to left which color goes where pretty easy?
If it was easy you wouldn’t be here asking us for help, would you?
I have never seen three wires slip out of a connector. They are usually well pinned in.
Did your mechanic buddy suggest going to a parts store to see the wire sequence on a new sensor?
Take a picture of your sensor, clearly indicate which connector your asking about and I’ll go out to my truck and see if I can help you out.
Discussion starter · #12 ·
I should be able to get it thanks I might be right already if so why am I throwing that code I just put a passenger side url catch can on it also never seen this on the first generation 3.5 .
Add catch can, then throw crankcase pressure codes.
Not exactly unheard of, and why the whole subject will never reach consensus.
Especially on a duel fuel Gen2 3.5 Ecoboost.
Discussion starter · #14 ·
Well according to the diagram I have my wires back in the right spot all along I will unplug catch can to see if that's the issue
Surprised no one has asked if the new crank pressure sensor is OEM or other. Also, ditch the catch can (concensus achieved as far as i am concerned 😉)
I’m afraid to ask anything. If I wanna get yelled at I’ll go talk to my wife. 🤠
Discussion starter · #17 ·
Yeah it's OEM who yelled and the catch can even ford makes them. I'm sure when I get my tune's from Torrie he fix the engine light.
Discussion starter · #19 ·
ok after a few months of working on stuff I am back to truck and I took catch can off and cleared code engine light comes back on
Whats the exact code? Grab me it I will post the diagnostic procedure for it Mike.
owns 2017 Ford F-150 Lariat
1 - 20 of 70 Posts
