41 - 60 of 70 Posts
Discussion starter · #41 ·
come on boatwaco you can help ? also just so anybody want to know I only use oem sensors thanks..
Ok. Let’s start fresh. You have a new pigtail, right? It is to connect to the sensor, right?
Please post a few photos of the wires in the truck and the pigtail that you bought. We will go from there…
Discussion starter · #44 ·
I dont want to hook up pigtail until im 100% on what color goes where post #10 shows yellow starting at right going left if im seeing it right ? not how I had it before, I think I had it the way the other picture shows of diff year, and it worked for a year ?
Discussion starter · #45 ·
when you look at post #2 diagram doesnt make sense as where it goes on post #10 it shows #3 wire in the middle but I dont know how to read that ? post #2 shows it going from 1 23 downward which hooked up would be left to right on top ?
Discussion starter · #47 ·
I have three wire and they are just hanging there right now I dont drive truck to work, I have a yellow a yellow green and a green brown or velvet whatever the last color is, why do you need pics they are just hanging.. another words they are not in the pig tail right now..
Discussion starter · #48 ·
ok I figured how do download pictures lol, this setup is not right I dont think should 1 and 3 be changed ?
Discussion starter · #49 ·
the replacement pig tail from part number I got from ford which is the same as anywhere the 3 wires are all green..
All I can find in my wiring diagrams for 2018 - 2019 Work shop manual wiring diagrams is that the Crankcase pressure sensor wiring seems to match your crankcase position sensor wires.
The Pressure sensor connector is in the lower half by the blue star. The wires are as seen coming out the back.
Perhaps the Green-Violet looks Green-brown.
Discussion starter · #52 ·
well it shows like i said before the picture I have 1 and 3 switched and yes the gr vt looks gr br
Discussion starter · #54 ·
cant somebody with a 2019 post a pic of there pigtail please!!! as I want to see if it matches the diagram ? thanks..
are your colors diff on your 2018 ?
I don't know. I am only looking at my physical wiring diagram book and the PDF wiring diagrams - while I am listening to work meetings.
Discussion starter · #56 ·
No problem I get out of work soon to hopefully someone will post a pic there are millions of these trucks..
When in doubt ohm out through the factory harness. Or use a multimeter to confirm which wire is which.
owns 2017 Ford F-150 Lariat
I did not. Probably just gonna replace the harness. Do you happen to know which one it is? I see many harnesses listed and am afraid I’m gonna end up with the wrong one
Calling you local Ford parts, or one of the bigger online Ford Parts retailers like Fairway Ford helps. They can use your VIN to ensure you’re getting the right harness. You just need to be specific in that the harness you’re looking for has the Crankshaft sensor or whatever on it.
This is a lot easier than looking at wiring diagrams or the not so specific listings online.
They’re really very helpful. Selling you the right parts is their job…
Discussion starter · #60 ·
[/QUO
well if you look at my other post I gave the part number to pigtail hey boatwaco I said I got my part from ford dealer of I switched wires 1 an 3 and no light drove around block no engine light, so no pigtail needed. so looking at my picture yellow is on left, and gr-vt on right.. anyway thanks for help..
41 - 60 of 70 Posts
