For those of you that are popping in let me narrow down the setups for our truck.
Ford did a VERY good job on handling crankcase pressure in this engines. There's no doubt about it. Crankcase pressure should only become an issue when pushing major power. Some companies took the correct route and improved on it. While others copied marketing tactics used on other vehicles.
Do you need a catch can? You don’t NEED a catch can but it doesn’t hurt to have one. But by all means if you feel you need one then buy one. Let me give it to you straight.(Gen 1) A catch can will not solve the carbon buildup issue PERIOD. It will happen no matter what due to it being DI.
Stratified has a very well in-depth article on this and I recommend you give it a read. Gen 2 on the other hand do have PI now. Let me clear up some information on this. Ford did not implement PI strictly for carbon buildup. It is solely for making more power efficiently while lowering emissions. A bonus of this is valves will be cleaned. There is so much misinformation out there making people think their trucks going to explode if they don't have a catch can. That's so utterly wrong.
A Catch can is ideally used to combat detonation from excessive blowby. These engines do not have excessive blowby if they are functioning as designed. If you are experiencing excessive blowby then something isn’t happy.
A properly working pcv on these setups should only produce gas vapors and a tab bit of oil. That's it. You should NOT be getting large amounts of oil in your kits.
Single Valve- JLT, Radium, Mishimoto, UPR all carry a single valve setup. A single valve setup is one that simply runs inline with the PCV side. Leaving the Cleanside Vent stock. This is a very street friendly design. Allows the stock pcv valve to function as it should pulling in fresh air thru the crankcase while the manifold is under vacuum. Keeps oil clean and retains the stock functionality allowing the cleanside vent to receive vacuum from the turbo inlet. Which aids with ring seal. Simple and very effective. Wouldn't argue running this setup. Ford Engineers designed it this way. Only difference being you are reducing the amount of vapors consumed. No issue at all with crankcase pressure. Perfect setup for running on the street.
Dual Valve- RX,UPR are the two big companies that came out with this setup. Well RX was the original creator for the product but never patented the technology and other companies copied. This setup was copy-pasted to every forum saying their cars engines had improper crankcase ventilation. Which is a bunch of nonsense. Anyways the idea behind a dual valve is that it will constantly pull fresh air thru the crankcase even in boost. They accomplish this by running a line to the pcv, turbo inlet, and intake manifold with a series of check valves. Then a line is used on the cleanside which is routed to the intake air filter housing. Which sounds like a phenomenal idea, but it ultimately turns the stock closed system into an open setup. Yes you now pull air thru the crankcase under boost but you remove the turbo inlet connection to the valve cover. You do NOT need to pull fresh air thru the crankcase when in boost. There is no need. You are only in boost a moment in time. Now instead of your crankcase experiencing a slight vacuum under boost it is now atmospheric. There's a downside to this as you will actually produce more blowby since the rings are fighting atmospheric pressure to seal. This can actually give off the illusion that your catch can is catching a bunch of crud that would pass thru. This system works for stock like power but ultimately not the best. From my testing the crankcase was atmospheric and at times became positive. Which I blame due to the long lines, routing, and check valves. Not ideal but it works. It's primary focus is keeping the oil clean while under boost.This is not an issue and never was an issue on these engines.
If you have a dual valve currently, and its working for you then that's great. All I'm saying is you're getting less than adequate crankcase venting especially under boost.
PCV Delete- Fullrace is the only company that produces a catch can kit solely for relieving crankcase pressure. This removes the intake manifold connection and vents the pcv side/ cleanside to the turbo inlet. Gutting the pcv. What this allows is any and all crankcase pressure to relieved by the suction of the turbo. This would provide you maximum crankcase ventilation with vacuum to aid ring seal. Removing the intake manifold connection guarantees no boost leaking into the crankcase. That's it. Simple and VERY VERY effective design. One downside with this is that you no longer have fresh air being pulled thru the crankcase but in reality it seemed to not make that big of a difference on the quality of the oil. This setup is what I would personally recommend if your sole purpose was making big power.
Code P051B- This code will almost always get set if you run a catch can. This code is thrown when the CCV sensor sees less than the desirable amount of vacuum provided from the turbo inlet. This is solely used for emissions and to notify the user that there is something wrong with the crankcase ventilation. It measure the vacuum to ensure blowby/contaminates are being sucked out and recycled to be burned for emissions.
I promise you will see a big difference in drivability when your crankcase is evacuating as it should.
