1 - 7 of 7 Posts
2013
I just watched a video on replacing the driver's side CV axle and they removed the strut.
My question is, do you REALLY need to remove the strut to do the job?
2015 Lariat 4WD
Out of curiosity, why are you replacing your axle?
On this style of truck I have done it both ways. It is MUCH easier to remove the strut...of course that is because I was replacing struts at the same time...
2015 Lariat 4WD
Same as @SrpRacing when NOT replacing struts. Reassembly is mainly just making sure everything is lined up before you torque back down.
Discussion Starter · #5 ·
I ripped it replacing the sway bar end links. Rust + broken socket wrench turned it into a 2.5hr job.
It's at 142k now, figured there's no sense in putting a boot on something that's going to need replacement soon anyway.
2015 Lariat 4WD
@Justinjs understandable!
My driver side front end pops and creaks sometimes when backing or slowly moving forward in a turn. I have IWE eliminators to go in, just have to do it.
1 - 7 of 7 Posts
