1 - 14 of 14 Posts
Hi, I'm experiencing the hesitation issue that's been seen so many times in this and other forums.
I hooked the truck (2011 SCrew) up to my code reader and it said there was a misfire on Cylinder 3.
This may be a stupid question, but how are the cylinders ordered on the 3.5? I've been Googling it all afternoon with no luck. :confused:
2011-2014 3.5L EcoBoost Cylinder Number and Firing Order
Did my plugs the other day since I had a misfire on cylinder 1, turns out the coil was bad too. Could not for the life of my figure out which cylinder was which. Went to the local AutoZone and pulled out the Haynes manual. Figured this was of some help.
Reactions: noodles
I read somewhere that it is passenger side front to back 123, and driver side front to back 456.
Reactions: scap99
Just had the same thing happened to me so I did some research before buying a coil pack and found out the spark plugs porslin can get a crack in it so I took the #3 plug out and what do you know there's a 1/2 inch crack in it.
Reactions: RMB_Ryan
Reactions: mwemaxxowner
Banned
Keep in mind that spark plugs are a big deal on these 3.5 ecos. Change interval is every 20k miles, use motorcraft sp534 plugs and gap to .030.
You may ask why change so often. Purely due to the intercooler building condensate and forced through spark plugs blowing them out. The fix is the 1/16" weep hole in the intercooler. This will help get the most out of the life of the engine.
So, is the 3.5 a odd or even fire engine? Always wondered. :)
Will this work on 2013 ford explorer sport 3.5l as well?
1 - 14 of 14 Posts
