1 - 5 of 5 Posts
I've been using dash cams for a while and found one you'll like to have in your truck.
I'm using the mini 0806 dashcam: mini0806 Dash Camera - HOME
It's easy to install and hides very well behind the rear-view mirror. The video is even clear enough so you can read a license plate on the car ahead of you! The power and gps are built into the base so it is easy to remove the camera to view the video or you can plug it into usb and download the video.
The cost, on e-bay, was around $100. Suggest you also purchase the custom wire kit.
Dashcam's are a 'must have' when it comes to being able to prove your side of the story in the event of an accident of if you're pulled over.
If you have any questions, please let me know.
Discussion Starter · #3 ·
BlackVue rocks, comes with two and holds a 64 gig memory card with built in wifi too view from the phone app.
How much does it cost Carlos? Sounds like more than $100
BTW: This one also has dual memory cards - can handle 128GB each.
My G1W is still working great also. Good picture and sound. Been almost a year with it. For 50 bucks you can't go wrong.
1 - 5 of 5 Posts
