1 - 17 of 17 Posts
2012 F150 3.5 EcoBoost FX4 SCREW
Has anyone tried this product out?
My IWE has been acting up and I'm wondering if I wouldn't just be better off replacing it with these?
If anyone has, any cons? Aside from the stated minor fuel economy hit, did your 4H and 4L still work just as well?
Thanks everyone
Everything will function as normal, the front half shafts will always spin though, where as now they do not.
I see you have a 2012. Have you ever had the front apart or done a lift? If not, I would replace the black selnoid and 3 prong check valve by the brake booster first. Start with the easiest thing first.
Discussion Starter · #3 · (Edited)
I did change those two pieces out and no luck unfortunately.
I had my front apart a couple of months ago to have the lower control arms and ball joints replaced. No lift.
If you had the front apart and took off the axle end nut, you probably messed it up. You have to spin the wheel to engage the IWE before locking the nut back down again. @winchested please chime in on procedure.
Discussion Starter · #5 ·
That's what I was thinking. I more then likely did mess it up.
Now I'm trying to decide to replace the IWE's or do the delete from Dorman and not have to worry about it again.
2020 Leadfoot Lariat
I went through two sets of OEM units on my '04. Swore I was going to eliminate them if I had another issue but got rid of the truck before it could happen. 16 years later and still using the same setup? Glad I paid more for it.
2013 XLT 302A 145" Screw
millions of these trucks sold every year and a small percentage have the issue. Seems worse because of the internet.
Very true. And to be fair, I put almost 100K miles on that truck in 4 years and lots of those mile were in upstate NY where the salt in the winter is ridiculous. Everything corrodes. That truck took a beating and owed me nothing!
Discussion Starter · #11 ·
Zero side effects other than the MPG hit.
Basically makes your truck like a GM or Dodge or Toyota.
Did you go with the Dorman or the RCV delete? I like the fact that you can plug off the vacuum line on the Dorman and that it fits like OE and is greasable.
What type of mpg hit did you get?
My experience is with unplugging the vacuum lines on the IWE's and leaving them engaged. I can't say I noted any more than a 1mpg hit for hwy use.
The country boy IWE eliminator!
Cheap and no fuss.
Cheap and no fuss.
This is what I have done currently with my pass side, see no MPG hit.
The process when doing the IWE's and tighteing the 13mm nut on the stub shaft is to either rotate the CV and make sure its locked into the IWE before tightening OR Using a mighty vac on the vacuum fitting and putting min 15" hg of vac on it before you tighten it up this opens the IWE up allowing it to be fully disengaged.
Any extra noise that sounds like humming, or whine/ tire noise like sounds.
There is the “slightest” additional noise and I do mean slight. I have to be on my street tires and have all the HVAC/Radio off to notice it. I’m one that is pretty particular to noise and vibrations.
Just to note, I have since installed the Dorman eliminators and very happy with the choice. They have held up to some 500whp launches with zero issues and 4x4 is there whenever I want it.
1 - 17 of 17 Posts
